Guys, I have 77 (L-48) with a Q-jet manufactured by Carter. Can't seem to find any model no. info on the carb. It's on the bench so it's not like I just can't get a good look. I've seen somewhere that it's supposed to be model # 7158. I have a Carter carbs book on order but my forum searches have come up empty regarding Carter carbs. Any help?
Carter made some of these when RPD (Rochester Products Devision) ran short on manufacturing capacity. The carburetor is a Rochester design, not Carter.
The ID number is on the drivers side of the carburetor at about the two o'clock position. It's a stamping so you may need to get some carburetor cleaner on the side of the carburetor to see it. It should be something like 17052057.
