low rpm miss
Old Jan 28, 2006 | 05:36 PM
toupstrio's Avatar
toupstrio
Default low rpm miss
CAn someone tell me an idea. 79 L82 engine sounds great at idle, but between 850 and 1400 rpm it has a miss. Does that sound like a vacum problem? Above that it seems to run fine its just that hesitation and miss on the low end.
Old Jan 28, 2006 | 05:55 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
I had something similar a few years ago. One of the carb tranisition slots had blockage in it. A good cleaning with carb cleaner and some pressured air did the trick.
Old Jan 28, 2006 | 06:29 PM
big_G's Avatar
big_G
Try pinching off the vacuum line that comes off the intake maifold that supplies the headlamp vacuum. Usually taps into intake runner #8. If there is a leak, #8 cylinder will have a lean miss.
Old Jan 28, 2006 | 07:03 PM
toupstrio's Avatar
toupstrio
Thanks for the info I will try Sunday am.
To low rpm miss
