Control Valve - Power Steering adjust?
Old Jan 28, 2006 | 07:20 PM
Rock'n Old's Avatar
Rock'n Old
Default Control Valve - Power Steering adjust?
How can I find out if the contol valve adjustment nut is in neutral/middle position?
Was hoping for some advise, before I touch it.
thanXalot ~~~~~~~~~~~~~
Old Jan 28, 2006 | 08:06 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Loosen the RAM rod from the frame end. Start engine and observe when it's centered and does not move in or out.
Old Jan 28, 2006 | 09:23 PM
vabeachvette's Avatar
vabeachvette
After I rebuilt mine I did what was stated above and then took if for a ride to see if it was pulling one way or the other, made one more adjustment after that and it was right on. Good luck.
Old Mar 2, 2013 | 01:33 AM
Cody's Corvette's Avatar
Cody's Corvette
So would tightening the nut adjust it right and loosening
Make it steer left?
After I rebuilt mine it started pulling right and I don't
Know whether how to adjust it
Old Mar 2, 2013 | 11:28 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
If I might make a suggestion, pick up a good Vette shop manual which will explain the procedure in detail. While a lengthy procedure to write up here, it's quite simple. A manual will help and keep you out of trouble with your Vette repairs and pay you back many times over.
To Control Valve - Power Steering adjust?
