What is the best way to remove the bushings from the rear crossmember? Crossmember was removed today and looking for advise. Also, are poly bushings available? Or, just rubber.
Those bushings usually do not wear and they don't need replacing. However, if you look closely, there are tabs that hold them in and have to be bent to be removed from the cross brace. Those bushings are not cheap either. I have not seen a poly bushing for them. Good luck!
Bernie
I agree most times they don;t go bad. If they're cracked or hard then replace them. they hammer out. There is also a alumninum disk and stud you can use to firm it up.
Your rear suspension looked as bad as mine did. I couldn't tell much about the condition of the rubber. I bead blasted and painted mine and reused the bushings. They are firm and do not squeek. If you don't like the looks of yours, if the rubber is flaking or peeling, I would replace them. Otherwise, clean and paint. Again the tabs have to be bent to get the bushings out and they go back in reverse order. Not hard just hard work. Good luck!
Bernie
I looked at the tabs holding in my original bushings, and then soon i had my grinder out and basically cut off the tabs. Once the tabs were removed, I used a 3 pound hammer to drive out the bushings. It was pretty easy.
The new repro bushings had to be pressed in. After the new bushings were in, I sealed off openings to the crossmember and then flooded it with Rustoleum Primer. Swished it around, and then dumped the excess. This crossmember is susceptible to rust since moisture, once it gets in, can't get out too easily.
