202 valves on vortec heads
Ok ordered my 64cc vortec heads today. My question is should I bring them to the machine shop and get them cut for 202 and 1.6 valves or am I wasting my time.
If the heads are new w/new valves ... its a waste of time & $. If the heads NEED new valves, then get the larger ones. Do have the spring heights checked/adjusted to allow for whatever cam lift you're gonna use.
You can get them new with 2.00 intakes from scroggin-dickey
http://www.sdpc2000.com/catalog/3129...inder-Head.htm
The bigger valves won't do so much ... you won't gain anything significant in low-to-mid rpm ranges. If your used iron heads have excessive guide wear; have thin-wall bronze "liners" installed.
