Head / Cam select ..... Again!
-Mark
Now that we have established that 200 runner is too big for my setup, I would like to compare the Performer vs. Vortec. Here are the flow numbers (both heads are 64 cc):
Lift 0.050 0.100 0.200 0.300 0.400 0.500
Vortec 40 70 139 190 227 239
Performer 32 64 121 174 216 235
Given the above information, Vortec heads are better (outflow) Performer. Correct?
Now, from the same article, an E/I ratio of 70-75% is considered good by experts. Vortecs are at 66%, Performers are 73%. With that information, Performer is a better head.
If one does not consider the price difference, which ones are better? One with better flow or better E/I ratio?
Since I would have to buy different intake and valve covers, Vortecs would be the same price as Performers. I am leaning towards Performers. They are aluminum (light weight) and have more valve lift/hp capability. Anyone disagree?
Is ur block decked?? If stock deck heigh is .025" and c.r. is in 9-9.5 range then iron vortec heads with .015" steel shim gaskets. Or block has been decked and c.r. is in 10-10.5 range then install aluminum heads with .039 composite gasket.
But the vortec's can use a little exh port work and need upgraded springs with screw in studs are more money. I think Scoggin-Dickeys has a resonable vortec head package.
But u need to fix that carb mixture and timing issue first.
cardo0
The way I look at the data on the CHP page is to take the flow numbers at all points up to my max valve lift and average them. This really shows how weak the World heads are. And no, I'm not dissing these heads. I'm simply saying there is something better. The World heads are very old technology. The Vortec and Performers were designed to get very high port velocities, this is the only way they can match the World heads with ports that are 30cc smaller.
All that said, the way I see it, the AFR 180's are the most versatile heads on the list. You could put them on a stock engine and they would do well yet they have the flow numbers to support some serious HP on a modified motor. If you can swing them they're the best.
BigBlockk
Later.....
cardo0
BigBlockk... "As far as bolt on and go with no port work at all, I would get the Performers".....SOLD
I looked into the price for AFR 180s....kinda pricy. I will pass.
Given all the information about my combo/usage of car, how does one go about selecting a good cam? And no, I don't wanna just call the Comp Cam Tech....been there, done that, not happy at all.
I am open to both solid and hydraulic cam. However, after using solid once, I would like to go back to hydraulic. Looking at the catalog on CC website, I can see myself picking one of the following cams:
Magnum 270H (1800-5800, biggest cam with stock convertor, use lower gears, mild rough idle, 224/224, 0.470/0.470)
XE268H (1600-5800, largest cam for stock convertor, 224/230, 0.477/0.480)
XE274H (1800-6000, 2200+ stall, 230/236, 0.490/0.490)
XS268S (1600-6000, largest cam for stock convertor, 230/236, 0.488/0.501)
Now here's my list of initial questions (and there WILL be more):
1. Operating Range: What is that? I can't extract any useful information from that. If my intended range is for 1500-5500 RPM, does that mean I can't select a cam in 1600-6000 range at all?
2. Druration: How does one select duration for their setup? I have had recommendation for anywhere 212 to all the way to 236. Help me narrow this down please
Also, given that I have practically open pipe set up, is it better to have same duration on exhaust side or bigger? I am assuming same is better since there is no restriction on exhaust. Am I correct?
Help me understand the above 2 itmes, then I will be back with questions regarding lift and LSA
When I selected my cam I contacted both Crane and Comp Cams. They both gave wery similiar advice. I ended up with the XE262H and am very satisfied
Have you dyno'ed your combo?
