Freeze Plugs
Old Jan 30, 2006 | 05:32 PM
lcwilson95's Avatar
lcwilson95
3rd Gear
Default Freeze Plugs
I have a leak out of the back of the block. Antifreeze is running down around the torque converter. I have replaced the freeze plugs on both sides of the block. I believe the 2 in the back need replacing.
Does the engine have to be pulled and disconnected from the transmission to repalce the rear freeze plugs?
Old Jan 30, 2006 | 06:12 PM
kdcollins's Avatar
kdcollins
perhaps you could pull the tranny instead of the engine?
KC
Old Jan 30, 2006 | 06:19 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Depends on how much room you have, you should be able to pop them out and install the new ones. If you have headers you may have to drop them to get around the header tubes. I've only had trouble with big blocks, not much room, but did it from underneath.
To Freeze Plugs
