Installing BB
Old Jan 30, 2006 | 06:02 PM
Chris69's Avatar
Chris69
Default Installing BB
Getting ready to drop in the 427. I have everything out, including the rad support and steering linkage. Given this amount of room, can the stock exhaust be attached first? How about fuel pump, or anything else I can get by with if careful? I'll be using a load leveler and a decent lift that is easy to roll around. Tnx!
Old Jan 30, 2006 | 06:07 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I still had to remove the fuel pump because it was hitting the front cross member preventing me from lowering the engine. I also had to remove the drivers side exahust manifold because is was running into the motor mount support.
I had the radiator, core support and hood off too. BUT, I was installing the engine & tranny together. Might be differetn for you.
