Differential "Howling" at 40-50 mph
Old Jan 31, 2006 | 03:27 PM
proracr's Avatar
proracr
Default Differential "Howling" at 40-50 mph
My differential seems to be howling at 40-50 mph. Can anyone give me a cause for this? Is it an indication that a rebuild is in order and if so, what kind of rebuild; new ring and pinion gears, limited slip clutches, etc. Thanks
Old Jan 31, 2006 | 03:37 PM
DR.Jay's Avatar
DR.Jay
Is this problem a sudded accurance, or has it gotten worse over time?
Improperly adjusted ring & pinion can cause a diff to howl. Have you checked the oil level? It could be any number of problems; bearing failure, Low oil Level, bad trailing arm bearing, Tire rubbing etc.
Let us know what you find.
DR. Jay
Old Jan 31, 2006 | 03:46 PM
proracr's Avatar
proracr
Thanks Dr. Jay! I have only had the car for about a month and driven it about 200-250 miles. I took the car to my local Chevy service department shortly after I brought it home and asked them to change the lubricant and additives in the differential, however, their tech was unable to remove the plug (go figure). So, I am unsure as to fluid level. I know that it isn't a tire rubbing or anything like that as I have been driving and racing cars for 43 years. I suspect that it is either low fluid level or ring & pinion adjustment, but then I am not a differential expert by any means. Are there any differential experts out there that can weigh-in on this?
Old Jan 31, 2006 | 04:39 PM
Gordonm's Avatar
Gordonm
Does it happen when coasting or accelerating. Mine were howling when coasting and would quiet down when accelerating. It turned out tha tthe gears were toast. I rebuilt it with new gears and properly set them up and the yare very quiet now. There is no adjustment on the gears.
Old Jan 31, 2006 | 04:57 PM
GTR1999's Avatar
GTR1999
Could be the gears or a bearing. May not even be in the rear end as tires can give you crazy howl if they get old and hard. New gears,depending on the make can howl too- even properly setup ones.
Since you are new to this car you probably don't know the history. Depending on where you bought it the history may even be " altered" somewhat from fact. Get the car to some one who can remove the fill plug and check the oil level. Have it sucked out and replace it with new GM posi additive and 90 wt gear oil. There were some here who used Royal Purple? and had good results. If that don't work swap a set of tired from another car to see if they are the problem before you go into the time and MONEY to rebuild the differential. New Gear alone (for good ones) are $275-$300 maybe more.
Good luck, let me know if you have any questions.
Gary
Old Jan 31, 2006 | 06:16 PM
proracr's Avatar
proracr
I think that it was howling on acceleration and deceleration, but worse on deceleration. Sounds like it probably needs a rebuild.
Old Jan 31, 2006 | 07:25 PM
GTR1999's Avatar
GTR1999
Well, if you want the paper to do the job let me know.
Gary
Old Feb 1, 2006 | 09:35 AM
proracr's Avatar
proracr
Thanks gtr1999, but I will probably pull the carrier unit out of the car and send it to Yogi Bair's for the rebuild or have it done locally if I can find a competent shop as I don't have the tools and facilities to do it here at home as I am renting and don't have a garage or workbench.
Old Feb 1, 2006 | 09:44 AM
SIXFOOTER's Avatar
SIXFOOTER
gtr1999, would it be possible to have you email me your paper? I have an 81.
danny.cunniff@adelphia.net
Old Feb 1, 2006 | 10:53 AM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
I had this exact same problem a few months back, it was the front pinion bearing in mine. It howled very loud on decel at speeds of 40-50mph.
Old Feb 1, 2006 | 11:49 AM
Cory1970's Avatar
Cory1970
Gary
Can I get a copy... mine has been slowly dieing for a while now. Cory7899@hotmail.com
Old Feb 1, 2006 | 12:33 PM
GTR1999's Avatar
GTR1999
Papers sent.
Old Feb 1, 2006 | 01:11 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
the howl is from pain. get out the checkbook.
Old Feb 1, 2006 | 04:43 PM
82Vette'ster's Avatar
82Vette'ster
Gary, Does your paper apply to 80-82 Dana 44's as well. I'd like a copy.
Old Feb 1, 2006 | 04:49 PM
GTR1999's Avatar
GTR1999
Sorry I wrote it for the Eatons used in the 65-79's. Some of the procedures can be used for the 80-82 but the posi is different. You're still welcome to read it,just pm me your email and I'll send it to you.
Old Feb 1, 2006 | 05:12 PM
sedowney's Avatar
sedowney
Pro,
you have PM.
Old Feb 1, 2006 | 08:11 PM
SHAT77's Avatar
SHAT77
Default diff noisy i work for gm and teach diff repair
If your diff is noisy first i need know when it is making the noise. are you accelerating or coasting ?
How long has it been going on ?
what work has been done to it and when ?
Is the diff warm or cold ?
Let me know and then we can talk
MIke
To Differential "Howling" at 40-50 mph
