Valve Covers Leaking
Old Jan 31, 2006 | 05:11 PM
wnmech's Avatar
wnmech
Default Valve Covers Leaking
Anybody out there had problems where you just cant get your valve covers to stop leaking? I have after market fairly expensive chrome valve covers on my 350 and I used new fel-pro gaskets and the left side keeps leaking no matter how loose or snug the bolts are. Thanks for the help guys.
Old Jan 31, 2006 | 05:21 PM
kona's Avatar
kona
I went from cast aluminum covers to really nice chrome steel ones and thats when I started having problems. Went back to cast aluminum covers with the Fel-Pro Dry fits and no more leaks.
Some steel covers tend to warp when they get hot.
Kona
Old Jan 31, 2006 | 07:15 PM
enkeivette's Avatar
enkeivette
Junk the stamped steel covers. My cast aluminum ones are in the mail right now.
Old Jan 31, 2006 | 08:52 PM
wnmech's Avatar
wnmech
Guys these arent the cheap valve covers rhey are G.M. performance parts and they are nickel/chrome plated covers. Do any manufacturers make a thick gasket that would compensated for any machining surface errors?
Old Jan 31, 2006 | 09:03 PM
ESC3's Avatar
ESC3
The gasket is not sealing to the valve cover.You need to scuff the rails on the valve cover so you can glue the gasket to it.Once the gasket is glued in place it will seal,but you still need the spreaders to help hold the rails down.
Old Jan 31, 2006 | 10:27 PM
enkeivette's Avatar
enkeivette
Doesn't matter how much they were or who made them or what they're plated with. If they're stamped steel ...
But if you don't want to buy new ones, with esc3, enough glue will work. If you rough up the surface and use gasgacinch that might work.
Old Jan 31, 2006 | 10:35 PM
SIXFOOTER's Avatar
SIXFOOTER
Just remember, Chrome will not get you home. I have trashed a couple sets of good chrome stamped steel covers. The aluminum covers are the best, but if you insist, scuff up the gasket surfaces and use GOOD steel spreaders with washers. Before you put them back on, check them with a straight edge across the bolt holes to see if they are still flat.
Old Jan 31, 2006 | 10:47 PM
fl_rider's Avatar
fl_rider
Default These should help
http://store.summitracing.com/defaul...5&autoview=sku
FEL-VS12869T $35.39
They resist high heat and vacuum.
Fel-Pro's PermaDry Plus valve cover gaskets feature precision edge-molded silicone rubber, which resists high heat and delivers reliable sealing on irregular surfaces. This silicone rubber is wrapped around a rigid carrier that adds strength to the gasket, to resist being sucked in under high vacuum or blown out when under pressure. At the same time, it also prevents over-tightening of the mounting bolts. Note, however, that these gaskets are not intended for race applications.
Old Feb 1, 2006 | 02:14 AM
panchop's Avatar
panchop
i use those blue permenant gaskets. they work great.
Old Feb 1, 2006 | 08:03 AM
wnmech's Avatar
wnmech
Who makes the blue permanent gaskets? I like fel-pro but I want to research both options. Thanks
Old Feb 1, 2006 | 09:50 AM
SteveG75's Avatar
SteveG75
Steel bends.
I use Mr. Gasket Ultraseal gaskets with my cast aluminum covers and ARP studs. The Ultraseals are cork gaskets with a non-stick coating so they don't tear when removing the valve covers.
Never had a need to glue the gaskets. No leaks and I can remove the valve covers easily.
Old Feb 1, 2006 | 11:27 AM
Hvymtlc5's Avatar
Hvymtlc5
Code:
FEL-VS12869T
I use these on my BB on they don't leak. They are very thick and hold up well to repeated removals (I've had the on and off at least 10 times) and they continue to seal everytime.
Old Feb 1, 2006 | 04:35 PM
ESC3's Avatar
ESC3
I have always used plain cork and have never had a leak.Like anything else,it's all in the prep.
Old Feb 1, 2006 | 06:52 PM
vabeachvette's Avatar
vabeachvette
same with me.......I can't wait to put them on!
To Valve Covers Leaking
