Rear end interchangablity
Old Feb 1, 2006 | 08:27 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Rear end interchangablity
Can I put a 72 Vette rear pumpkin / carrier in my 78? From research, all I may have to do is change the spring mounting plate? Is this correct?
Old Feb 1, 2006 | 09:19 AM
BigBlockk's Avatar
BigBlockk
As far as I know they are interchangeable.
BigBlockk
Later.....
Old Feb 1, 2006 | 10:17 AM
junkman104's Avatar
junkman104
The junkie bible acording to: Hollander says,
1 CORVET 66-79 737B
2 CORVET 63-65 737A
When interchanging A & B it is necessary to include the carrier bracket bolts & nuts.
Has two carrier bracket bolts at front of carrier.
ID #s: 464906,464907,3876473,3899139,3899141
Old Feb 1, 2006 | 10:21 AM
GTR1999's Avatar
GTR1999
Yes the carrier from the 72 will fit the 78 housing. You'll have to set it up of course as the shims and pattern will not be the same.
Old Feb 1, 2006 | 10:58 AM
Hvymtlc5's Avatar
Hvymtlc5
May have used the wrong words....was talking about the complete differential.
Old Feb 1, 2006 | 01:16 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Yes it bolt in. You have to change the mounting plate and spring. You can avoid doing this by taking the cover off of your original diff and put it on the 72 diff.
Old Feb 1, 2006 | 02:02 PM
Hvymtlc5's Avatar
Hvymtlc5
Good to go. Thanks for the confirmation.
To Rear end interchangablity
