Numbers help on 327-300
Old Feb 1, 2006 | 12:54 PM
Ronnie wilkins's Avatar
Ronnie wilkins
Default Numbers help on 327-300
Need help on the # on 327-300. the number is 3903352. IT HAS Double hump heads and a steel crank. Anyone interested in buying this motor?
RW
Old Feb 1, 2006 | 06:48 PM
Greg's Avatar
Greg
Just another Corvette guy
Hey Ronnie,
3903352 comes up as a 1967, 327 2 bolt block. Application shows Passenger, Chevelle, Camaro and Corvette with horsepower ratings from 210 to 350. If you have the engine code suffix stamped on the front passenger side below the head I can narrow down its original application for you. If you want to sell it I'd eBay it for the biggest possible market. Someone re-doing a '67 Corvette will probably jump on it.
Greg
Old Feb 2, 2006 | 07:02 AM
Ronnie wilkins
Greg, thanks for the info. Ill check the for the other numbers and get back.
RW
To Numbers help on 327-300
