Stud Girdles on BB ?
Old Feb 1, 2006 | 05:05 PM
fst_c3's Avatar
fst_c3
Default Stud Girdles on BB ?
We got all new roller set up. Ran real fine for about 100 miles. Then I lost a keeper on an exaust valve, broke the guide, bent the rod. Very lucky i retrived all the peices and the valve didn't drop.
I'm thinking the roller rocker wasn't riding where it should to cause that. I have the parts to replace, but started thinking is Stud Girdles a good idea?
Old Feb 1, 2006 | 05:14 PM
gerry72's Avatar
gerry72
A stud girdle has nothing to do with the rocker position except in a dynamic state and then only fractionally. If the rockers aren't where they're supposed to be with the enigne off, then a stud girdle won't be of any use to you in preventing this kind of failure. The real purpose of a stud girdle is to stabilize the studs so that they don't bend and have cyclic failure. Usually the stud will break off just below the rocker fulcrum or right at the base.
I would look at your guideplates and the rocker geometry.
Old Feb 1, 2006 | 05:26 PM
norvalwilhelm's Avatar
norvalwilhelm
I believe in a stud girdle and always use one. That said I also found that stock push rod lengths don't work with installed heights of over 1.875. If you are using aftermarket heads there is a good chance your rockers are actually touching the retain. I am in the middle of correcting this problem right now
Old Feb 1, 2006 | 05:55 PM
fst_c3's Avatar
fst_c3
I have GM LS-6 hp heads on a 427 and the K11-420-8 kit from comp cams. You maybe right about touching the retainer, it had a small crater on the one that broke. How can I be shure on the rod length?
Old Feb 1, 2006 | 06:10 PM
gkull's Avatar
gkull
Loosing a keeper can only be caused by a couple of things. At least it's the only two I know about.
#1 improper installation.
#2 Bottom of the rocker having contact with the retianer.
I'm running a solid roller with +.200 push rods and +.100 vavles with longer ARP studs because my spring diameter is so big that i had bottom of the rocker contact with my retainers.
I would never grind the rockers to gain clearance. I also never leave home without a stud girdle. Once you get up to 175+ pound seat pressures you can actually measure the stud deflection on a dial indicator by rotating the motor over twice. If your deflection exceeds .020 you need a stud girdle.
Old Feb 1, 2006 | 07:57 PM
norvalwilhelm
I went out and put a stock pushrod in one of my exhaust valves and took a picture
This is a rocker arm touching the retainer. Us a mirror and look carefully
I run .100 longer pushrods and that takes care of this.
Another problem with stock length pushrods can be the slot in the bottom of the rocker touching the stud because it doesn't have enough travel
Old Feb 1, 2006 | 08:02 PM
norvalwilhelm
This is the same valve and rocker with a .100 longer push rod
Old Feb 2, 2006 | 02:13 AM
fst_c3's Avatar
fst_c3
I will get a sideview picture. You can see the damage on the retainer.
thanks for the help [IMG][/IMG]
Old Feb 2, 2006 | 10:49 AM
gkull's Avatar
gkull
When you said roller setup I was thinking "Roller" setup. your picture kind of tells it all.
Roller tip rockers are bullet proof in comparision to stock stamped rockers. They are great for hot H-flat cams.
What you need to do is read up on valve train geometry. Stug girdle would be a waste of money for your setup. What you need is correct length push rods which have clearance and center on the tip of the valve stem throughout it's complete cycle.
To Stud Girdles on BB ?
