Vette runs after shut off....
Old Feb 1, 2006 | 09:40 PM
HT1663WB's Avatar
HT1663WB
Default Vette runs after shut off....
Hello, I have a 1977 Corvette 350/4 speed when I shut the car off the engine continues to run for about 30 seconds with gen light on before finally shutting off. I did install an electric fan.. one wire grounded to frame and the positive is run right off of the ignition wire to the distributor. Fan shuts off but engine doesnt for approx 30 seconds. Any help would be appreciated..Thanks, Bill
Old Feb 1, 2006 | 10:01 PM
MrEldo's Avatar
MrEldo
Timing is too advanced - retard it a bit. How is your operating temperature; a bit on the high side?
Old Feb 1, 2006 | 10:16 PM
HT1663WB's Avatar
HT1663WB
The car is running normal after the key is turned off. Its not bucking its running smooth I know it sounds crazy. The temp never even reaches 200.
Old Feb 2, 2006 | 12:05 AM
MrEldo's Avatar
MrEldo
In that case you may need a new ignition switch.
Old Feb 2, 2006 | 12:22 AM
Greg's Avatar
Greg
Just another Corvette guy
Bill,
I've seen this before. You need a different hot source for the positive side. The positive is being fed by the ignition lead and the engine will continue to stumble on uintil the fan stops spinning after you key off.
Want to check it? Unhook the fan positive lead and see if the car shuts off normally.
Good luck,
Greg
Old Feb 2, 2006 | 11:51 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Originally Posted by Greg
Bill,
Good luck,
Greg
Old Feb 2, 2006 | 11:54 AM
pik's Avatar
pik
I had a similar problem after installing an MSD igntion. I needed to install a diode (electrical checkvalve) in the alternator line. No problem now. This may work for you too.
Old Feb 2, 2006 | 02:09 PM
HT1663WB's Avatar
HT1663WB
Thanks guys for all your help! I rewired the fan today and that fixed the problem. Thanks again, Bill
To Vette runs after shut off....
