Elec Tach Problem
Old Feb 2, 2006 | 10:44 AM
Gage's Avatar
Gage
Default Elec Tach Problem
I just retrofitted a tach from a 75 in my 72. Worked fine for a month or so, but now, the needle wanders down to 2000 rpm when I am cruising and it should be around 2700...When I punch it, it then "catches" and spins around correctly...Do I need a new circuit board? I hope not since I am not looking fwd to pulling the dash apart again.
Old Feb 2, 2006 | 01:42 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Make sure all connections are tight. Most of the time at the distributor the push on gets loose. Use a Tach filter as well, makes a difference stops spikes
Old Feb 6, 2006 | 10:08 AM
Gage's Avatar
Gage
ok, I'll check the connections. I am using a tach filter btw.
Old Feb 14, 2006 | 03:50 PM
Gage's Avatar
Gage
anybody else have this problem and what did you do to fix it. connections are all tight.
To Elec Tach Problem
