My 76 dose not start.
Old Feb 3, 2006 | 04:31 AM
akstreker's Avatar
akstreker
Default My 76 dose not start.
Like I said i have a 76, with a none telescopic steering colum. When i turn over the key the car dosen't start. But I have been abole to jump the starter and it turns over fine. I also tested the starter wire with a multimeater and it shows no activity. Any tests I should do? or has anyone ran into this problem before?
Old Feb 3, 2006 | 07:12 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Default sounds like a bad starter switch
sounds like a bad starte switch to me, its located on the column
tim
Old Feb 3, 2006 | 07:19 AM
Razorhorn's Avatar
Razorhorn
I have seen a lot of strange problems with starters. This sounds eerily similar to an issue issue with my wife's SUV about three months ago. Current draw with the ignition in the ON position seemed normal. But I couldn't get the motor to turn over unless it was jumpered. It ended up being a bad starter. With your door closed and all accessories turned off, what kind of current is being pulled when the ignition switch is in the ON position?
Old Feb 3, 2006 | 08:19 AM
1Z87L8's Avatar
1Z87L8
if its automatic trans it could be the neutral safety switch.
if it is an AT car try it in neutral as sometimes they will get out of adjustment and wont start in park
To My 76 dose not start.
