Blower motor wiring help please
Old Feb 4, 2006 | 12:02 PM
shad2s's Avatar
shad2s
4th Gear
Default Blower motor wiring help please
I posted this in the general area but this looks like it might be the better place to ask this. I am rebuildimng a 69 vette with A/C and the wiring involved has been badly butchered and I am trying to get it all back together again. Unfortunately for me the ability for me to connect color to color is gone due to all the cutting and splicing that has already happened. So, I was hoping there was someone out there that could help me connect the dots and get the blower working again. Btw, I have tested the blower by itself and it does in fact turn so I know it is a functional fan. The biggest mystery right now is the A/C blower relay that mounts on the Evap case. I think if I get that part figured out then the rest might fall into place. Right now the wires coming off it are clipped off so the only thing I can tell is the colors. (which are only be correct if that is the original plug) There is one plug of three wires then a single wire plug, can anyone please help me figure out where they go?
A/C Blower Relay
Three Wire Plug
Red
Black
Green
Single Wire Plug
???? nothing there
Also, one part of the heater resistor also has me confused. The heater resistor is a three wire plug but the yellow wire splits. One half of the yellow wire goes into the firewall to the blower motor switch on the center console, the other half I have no idea.
any help is greatly appreciated!
Shad
Old Feb 5, 2006 | 11:57 AM
shad2s's Avatar
shad2s
4th Gear
Default Maybe just validate one wire for me?
Can anyone validate that the red wire on that three way plug on the A/C blower relay (which is usually located on the evap case cover) comes from the horn relay on the other side? I have the Chiltons manual, the GM assembly guide, and an EZwire thing I ordered online and none of them have this little relay wiring. I have gone through hundreds of Ebay pics trying to get a glimpse of this relay just so I can get this wiring hooked up. The GM assembly manual shows the parts being installed in their appropriate locations but does nothing to help me as far as the wire colors or where they originate from. As always, any info will be of great help. After 7 years of frame off rebuilding I am getting into the home stretch. I had all my dash and center console put together and had to tear it all back apart to try and figure out this heater and A/C wiring. Gotta love them project cars!
thanks,
Shad
Old Feb 5, 2006 | 12:55 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
I looked at my 68 chassis service manual to see if I could ID any of the wires you are talking about. Either the color code is different for 69 or someone has done some rewiring (or both). In any case, the 68 diagram might be of some help to you. Maybe someone can post the 69 from the chassis manual.
Old Feb 5, 2006 | 01:00 PM
BBShark's Avatar
BBShark
Looks like the image host has reduced the file size of the image above (to where you can't read it if you zoom). Send me an email and I will send the high res version.
Old Feb 5, 2006 | 01:22 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
thanks,
Shad
Shad,
The red wire you ask about should be black 10 ga wire from the horn relay to an inline fuse and from there on to the relay.
You should give serious consideration to replacing the entire harness and getting a really good diagram (like the ones I offer). Even if you don't get mine, get a good one and in color.
Just a few locations where I'm mentioned.
http://www.vetteheads.com/forums/showthread.php?t=4838
http://www.vetteheads.com/forums/showthread.php?t=5458
http://forums.corvetteforum.com/show...3&forum_id=119
http://forums.corvetteforum.com/show...194&forum_id=3
Don
Old Feb 7, 2006 | 12:39 AM
carl a's Avatar
carl a
A/C Blower Relay
Three Wire Plug
Red
Black
Green
Single Wire Plug
???? nothing there
Shad
don olson sells these colorcoded diiagrams. he has the bulb data,the fuse data. and every wire in your car will be the same on diagram his number is (630)947-3284also there sealed in plastic
To Blower motor wiring help please
