Handy little engine dolly
Old Feb 4, 2006 | 01:51 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Handy little engine dolly
Just got the 406ci back from the dyno shop and needed to put it on something for a while. Went out and got this slick engine dolly, was only about 25 bucks. The motor just sits on the four "stilts" and you can easily roll it around the shop. Not for transporting though
Old Feb 4, 2006 | 01:57 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I have a motor sitting on my engine lift, where did you get this little gem. Thanks for sharing this...
Old Feb 4, 2006 | 02:12 PM
MotorHead's Avatar
MotorHead
Got it at Princess Auto, the only store I would ever go and browse
Old Feb 4, 2006 | 03:49 PM
jackson's Avatar
jackson
That's universal sit-on ... Same thing available that bolts to chevy motor mounts & bellhousing holes ... same $ ... motorville P/N MTR.ED1000 ph 1-888-463-0482
Old Feb 4, 2006 | 03:56 PM
Glass Act's Avatar
Glass Act
Thanks again MotorHead
I'm off to browse
wife says I say
Old Feb 4, 2006 | 05:35 PM
Gordonm's Avatar
Gordonm
I need something just like that. I will be indexing my bellhousing on the new block and need something like that to hold the motor. I can't have it bolt to the back of the block. The other option is the leg style tha tbolts to the engine mounts. Don't want to spend a bunch as I probably won't use it much. I'd like to be able to find someone local and borrow it for about a week. Chances are slim on that.
To Handy little engine dolly
