Upon further review, the rear brakes were just a little bit too strong for good balance.
Van Steel bailed me out by sending me a regular steel brake line to fit my application. (I could not put double flares in the stainless steel line with my hand tools.) In the line running from front to back along the frame rail, I installed a Wilwood brake bias adjuster. Everything works great now, however, the pads do require a little heat.
By the way redvetracr, you mentioned having AN hose ends. Do you have any -20 fittings? I have some calipers & brake pads I can trade you, if interested.
I don`t use -20 so I don`t have any but I suppose I could get it. what angles are you looking for?? figure it out and e-mail me direct!! redvetracr@msn.com
So when are you going to tell us about your gas tank mod? Originally Posted by TZ Racer
some kind of fuel tank modification to keep fuel around the pick-up.
I think we will be using some sort of duck-foot style setup since, at this time, we have a stock steel tank and limited access. I guess if I can't make it work, we'll end up with a fuel cell.
