Delay wipers need HELP!
Old Feb 4, 2006 | 07:31 PM
icanfixitforyou's Avatar
icanfixitforyou
Default Delay wipers need HELP!
Hi, I replaced the wiper switch on my 79 and my delay wiper circuit still does not work. Is there a relay under the center console that controls the delay for the wipers? Does anybody know how to repair this issue?
Thanks!
Old Feb 4, 2006 | 07:45 PM
kona's Avatar
kona
The relay is located in the storage compartment behind the passengers seat. If you can find one they are around $350 and up for a used one.
Hope you were sitting down when you read that. If your wipers quit working completely due to a bad relay you can get a jumper from Lectriclimited for around $15.00 that will restore the slow and fast speeds but no delay.
Kona
Sorry didn't catch that you had a 79 in the 80 it's behind the seat.
Kona
Old Feb 4, 2006 | 08:24 PM
chevylit's Avatar
chevylit
I have 2 79s and the delay relay is under the center console on the
drivers side on both of'em. My delay quit on one of mine but a new
switch fixed it but appearently not on Yours. There was a relay on
Ebay a couple of weeks ago for 125.00 but it was of course used and
very possibly no good.
Old Feb 4, 2006 | 11:55 PM
icanfixitforyou
Does anybody have a picture or a good description of the relay?
Old Feb 5, 2006 | 02:26 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
This help at all?
Mike
Old Feb 5, 2006 | 02:57 AM
mrvette's Avatar
mrvette
The very first thing to do is take the plastic housing off that controller assy, carefully, and note if there are any bad solder connections around the interconnect pins or any other component such as a relay proper.....GM boards are famous for these open solder joints, as are any other brands....
GENE
Old Feb 5, 2006 | 11:01 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
GENE
Good tip. I've got a couple of replacement controllers (used) that are just as broken as the original. I was thinking of pulling one appart and having a look inside and at least now I have some idea of what to look for.
Old Feb 5, 2006 | 11:35 AM
icanfixitforyou
Hey Mike and Gene,
Thanks - That is just what I needed!
Lee
To Delay wipers need HELP!
