Witch hole to put it?
Old Feb 5, 2006 | 08:50 AM
Rock'n Old's Avatar
Rock'n Old
Default Witch hole to put it?
Where can i place the temp feeler for my thermal switched electric fan?
(I need at least one serious answer)
Old Feb 5, 2006 | 09:04 AM
GDaina's Avatar
GDaina
prolly in the intake by the thermostat housing, on my BB, I placed it in the cyl. head
oops...how about the cyl head?
Old Feb 5, 2006 | 10:12 AM
Ninteen79's Avatar
Ninteen79
Navigator
On the 79L82 there is a sending unit hole on the passenger side head located between #6 and #8 cylinders. Maybe your 69 has a plug there that you can remove.
Old Feb 5, 2006 | 11:33 AM
moosie982's Avatar
moosie982
O.K. You asked for it,,,,,,,,pick one the gets HOT,,,, Peace,,,Moosie
Old Feb 5, 2006 | 11:40 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I installed mine in the passengers side head.
Old Feb 5, 2006 | 12:59 PM
cchristo's Avatar
cchristo
I just put mine in the upper radiator neck and put the hose over it. Been working perfect for years now, no leaks. Fans come on exactly when I want them to.
Old Feb 5, 2006 | 03:37 PM
Jims79's Avatar
Jims79
[QUOTE=Rock'n Old] Where can i place the temp feeler for my thermal switched electric fan?
I wouldn't stick it in the wicked witch of the west. you have to drink alot of green beer first.
Old Feb 5, 2006 | 05:12 PM
Rock'n Old's Avatar
Rock'n Old
Well, I don't know any witch from the west, but green beer sounds OK.
But I think I have an idea of what kind of hole I need, and I think that
I would like to try the passenger head-hole. . . . . sorry, passenger side
hole in the head . . . . . . .passenger headside . . . .
maybe an on off switch . . .. . . . . . . . . . . . .
Old Feb 5, 2006 | 08:12 PM
shafrs3's Avatar
shafrs3
Old Feb 5, 2006 | 08:18 PM
73 Vet's Avatar
73 Vet
I used the passenger head "hole" on my BB, but it didn't work very well; got hot too fast and stayed that way. Put it in the water neck, or, put a tee in the heater hose coming out of the intake.
Old Feb 5, 2006 | 09:59 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I put mine in my water pump.
http://img.photobucket.com/albums/v7...ejr/Engine.jpg
Old Feb 6, 2006 | 07:19 AM
UKPaul's Avatar
UKPaul
Ummm.... whichever smells the best?
Probably a bit OTT if you can use a hole in a head, but the '81 had a coolant sensor fitted for the computer. It was in the intake manifold to the p. side of the stat housing. My new Performer manifold had a small round flat with a dimple in the correct place so I drilled & tapped it for the sensor. Works great.
To Witch hole to put it?
