From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
I Really Need Some Help From 80/82 Model Owners
I really feel my trans may be sitting a little high. I need to finish my
crossmember modifications. I need to move on and get it done. I have
been switching project on the car, so I don't get burned out. Its working out pretty well.
this is what I need. Will someone please measure the top of the rear
crossmember to the drive shaft like in the pic. I don't know if 73/79
are the same as 80's models, so that why I ask for the 80's models
measurement. I know it's a big deal to go jack up the car and take a measurement. But I need to make sure I get this right. Maybe someone
has their car already jacked up.
From the top of the rear crossmember to the driveshaft I have 1 3/4
inch.
OK, don't know if you'll want to go with this, maybe as additional reference. Measured both my 79s, no big deal as one's up on stands for brakes and the other's up on the hoist. Both are 1 1/2".
Mike
Mike
Thanks, anything helps
I'll wait to see if anyone else comes up with the same #'s
MEGALADON,
Didn't get over to the Vette last night (one of the joys of my job) but I'll make a point of driving over tonight to jack it up. Apart from anything else, I want to see how a winter in a damp garage has affected it
If you think the trans is to high, then the following info could be useful:
Th350C trans. With a straight edge placed against the lower edge of the chassis & run across the car, the lower edge of the yoke shaft is 3" above the edge at the point where it exits the trans oil seal ie. pass a length of straight wood under the car, lift it up to the chassis at each side & there will be a 3" gap between it & the shaft.
As you're looking at the trans possibly being wrongly positioned, is that info what you need, or do you still want the gap at the rear as well?
Meg, you should have built the crossmember lower so you can shim the transmission up, there's no way to shim it down so any adjustment that you can build into it can only be done by building it too low. I hope it's okay as it is but it looks kind of high in whch case you'd have to redo it.
I bet you are right TWIN. I know I could get away with it
if I could find a trans mount about half an inch shorter then the
one I got.
Most likely, I will cut the bottom trans plate off, and reposition
it a little lower.
If anyone knows where I can get a shorter trans mount, please
let me know
If anyone knows what the engine inclination is supposed to be you could check it easily. Does the trans stay clear of the tunnel and does the stick fit properly? How about the crank pulley to crossmember clearance, all those are indicators of an incorrect engine inclination. It isn't too much of a problem apart from the engine mounts twisting (the rubber, or urethane part, assuming you don't have solids) I have my transmission tucked up rpetty high also so I have max. ground clearance. The pinion and talshaft angles can be adjusted to match so you don't get vibration.
Here's mine, look at how high the output shaft sits here.
I'm not aware of a shorter mount being available, mine's pretty high also because it adapts to the ZF6 c-beam mount with an adapterbracket.
Tried this out on my 79. Came up with 3 3/4". Measured from the top of the 2X4 held up to the frame rails just behind the crossmember to the bottom of the yolk just as it leaves the trans.
For a quick look, bottom surface of driveshaft at the front is about 1/2" below the floorboards at either side of the tunnel.
Don't forget to check to see how your fan sits in the shroud. Lower the *** too much and the fan sits too high. This is more and more a problem with all the different manufacturer's for engine mounts these days. Of course as said above if your aft mount is already too high your hosed.
.Mike
Maybe the 80 - 82 are slightly different? The measurement I got was the same as Dallanex kindly took from his '81 as well.
MEG,
Measured the gap last night &, in exactly the same position you were measuring in your pic, I got a measurement of 1 1/8".
As for engine inclination, the STOCK fan with the stock shroud is VERY close to touching at the highest point (which is why I spent so much time checking out the heights). Dropping the trans down even slightly at it's mounting point causes the fan blade tips to actually touch the shroud, so there's not a lot of room for error. As I'd taken the shroud, rad, support, etc out for a spot of R&R the chances are that I've got them back in place a bit low but, even so, it's pretty darn tight in there!
edit: some more info that might help. While messing about with mine I called Corvette Kingdom in the UK. They had an '81 in the workshop at the time so got it up in the air & took a measurement for me. What the measured was a distance of 3 5/8" from the lowest point of the shaft where it exits the tranny oil seal to the face of the cast plate fxed to the tunnel above it. That was a totally stock '81 so the above measurements should let you get it set up spot on.
