How do you check u-joints
Old Feb 6, 2006 | 01:46 AM
yellow71's Avatar
yellow71
Default How do you check u-joints
I have half shafts and driveshaft out. Both driveshaft joints are kind of tight and have a "catch" in them when moved. Half shaft joints are smooth and easier to move. What is the criteria for replacement?
Neil
Old Feb 6, 2006 | 03:12 AM
enkeivette's Avatar
enkeivette
They're cheap, just replace them while you're in there.
Old Feb 6, 2006 | 07:24 AM
My Second Job's Avatar
My Second Job
5th Gear
If the driveshaft joints have a "catch" they are most likely bad. The half shalts outer joint usually fails first. If you have grease fittings, grease the joints and look for any trace of orange on the grease that comes out.
Old Feb 6, 2006 | 07:43 AM
comp's Avatar
comp
Old Feb 6, 2006 | 08:32 PM
StickShiftCorvette's Avatar
StickShiftCorvette
U-Joints should work smoothly and have no lost motion as torque is reversed across each joint. Any that are not smooth or have ANY visable lost motion should be replaced. For the outer half shaft joints, it is VERY helpful, imperitive in my mind, to bolt up the flange to a heavy steel plate when driving the U-Joint cups into the flange.
To How do you check u-joints
