Steering wheel position
Old Feb 6, 2006 | 05:13 PM
kona's Avatar
kona
Default Steering wheel position
On my 80 the steering wheel is sitting in the wrong position when the wheels are pointing straight. Can I take a puller and remove the wheel and put it back on straight or does the shaft have a keyway preventing this?
Kona
Old Feb 6, 2006 | 05:23 PM
GDaina's Avatar
GDaina
Kona
Yep, that's how they do it in the alignment shops...
Old Feb 6, 2006 | 05:29 PM
kona's Avatar
kona
Thank You Sir.
Kona
Old Feb 6, 2006 | 06:01 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
A good alignment shop can do it with the tie rods. As long as the steering box is properly centered, you can just pull the steering wheel and re-install. Mine's upside down right now...
Edit: point taken about the cancelling cam.
Old Feb 6, 2006 | 06:25 PM
big_G's Avatar
big_G
Wait just a minute...not so fast....lol. In order for the turn signal cancelling cam to work correctly, the steering wheel hub must be indexed correctly to the shaft. Look for a scribe line on each part. These are factory markings. Once these are lined up, then you can have the alignment shop center the wheels at the tie rods...
Old Feb 6, 2006 | 06:43 PM
mrvette's Avatar
mrvette
BigG is totally correct and anything else is BS of the lowest order....
GENE
Old Feb 6, 2006 | 08:22 PM
StickShiftCorvette's Avatar
StickShiftCorvette
GENE
I'll also add that if you misalign the steering wheel to the shaft you will also loose the correct "high center" steering gear preload in the straight ahead direction. This greatly impairs steering feel while driving straight.
Old Feb 6, 2006 | 08:40 PM
kona's Avatar
kona
Damn I thought I was going to get off easy.
Kona
Old Feb 6, 2006 | 08:52 PM
kdf1986's Avatar
kdf1986
Wouldnt the answer be with how much of an offset you are talking about? If it is off only a little, I think the tie rod adjustment would work. If you are talking about 1/4 to 1/2 out of orientation, then there is another adjustment to be made somewhere.
kdf
Old Feb 7, 2006 | 12:27 AM
Jim Shea's Avatar
Jim Shea
Here is a link to a paper on steering wheel centering.
http://jimshea.corvettefaq.com/wp-co...mCentering.doc
Don't try and use the links in the paper for the tie rod information. They go to the old Corvettefaq.com websight. Here are two other links to the new websight.
http://jimshea.corvettefaq.com/wp-co...-Rev21JA06.doc
http://jimshea.corvettefaq.com/wp-co...ised14FE04.doc
Jim
Old Feb 7, 2006 | 02:56 AM
mrvette's Avatar
mrvette
Kona
Kona, pay attention to Jim's papers there, he the guru, and Stickshift is also correct , good point there....
GENE
Old Feb 7, 2006 | 09:48 AM
kona's Avatar
kona
Printed Jim's paper this morning and will tackle this over the weekend.
Thank's for everyones help.
Kona
Old Apr 23, 2006 | 08:39 PM
tab4's Avatar
tab4
1st Gear
How would you reccomend the easiets way to straighten my 82 CE steering wheel?
To Steering wheel position
