Vapor Lock Tips???
Old Aug 8, 2001 | 06:59 PM
StingRay327's Avatar
StingRay327
Default Vapor Lock Tips???
My vette runs great but when I park it after it has heated up, it will not start until the third time I crank it over.
The starter cranks over perfect every time. If I shut it off, it will fire right back up instantly within 10 minutes of turning it off. But after ten minutes or so it seems a little hard to start.
I use to have a clear fuel filter right by the carb and when I was done driving I could pop the hood and see air bubbles just filling up the fuel filter.
I replaced the fuel filter with a regular steel one in the same place. Should my fuel filter be somewhere else so it doesn't catch a whole pocket of air there?
Old Aug 8, 2001 | 07:06 PM
mulchie's Avatar
mulchie
Default Re: Vapor Lock Tips??? (StingRay327)
It sounds like we're both having the same problem. My LT-1 does not have and external fuel filter but it does feed from a single line whereas the base has a feed and return line. I'd also like some tips on vapor lock.
Old Aug 8, 2001 | 07:14 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Vapor Lock Tips??? (mulchie)
You could try installing a heat shield with a thin 3/8" spacer to help keep the heat fromm transferring up into your carb & ultimately your fuel. I installed one from Summit Racing for I think around $25. I think some of the 1st gen Camaros actually might have come from the factory with a similar set up.
Hope this helps, not much money to try. Maybe others will have a better fix or suggestions.
Old Aug 8, 2001 | 07:18 PM
SmokedTires
St. Jude Donor '05
Default Re: Vapor Lock Tips??? (mikeo)
stingray327 your sig reminds me a lot of my car in this picture :D !
Old Aug 8, 2001 | 07:22 PM
StingRay327
That's a great looking hood!
Old Aug 8, 2001 | 07:27 PM
SmokedTires
St. Jude Donor '05
Thanks :D
Old Aug 8, 2001 | 08:00 PM
Jvette73's Avatar
Jvette73
For one thing, if you car was equipped with a return line sys make sure it stays hooked up. Sometimes when people switch to aftermarket fuel pumps they just bypass and plug the return line. Not a good idea for a car that will see high underhood temps. Go the extra and take the steps to retain the return line when switching to a different pump.
To Vapor Lock Tips???
