Thermostat Temp.
Old Aug 8, 2001 | 07:46 PM
LT1man's Avatar
LT1man
Default Thermostat Temp.
Does anyone know the right thermostat temperature for a 71 LT-1. 195, 185 or 160 degrees.
Old Aug 8, 2001 | 07:51 PM
Jvette73's Avatar
Jvette73
Default Re: Thermostat Temp. (LT1man)
Its not that big of a deal really. Personally I would go with a 160. The motor is gonna run hotter than that anyway.
[Modified by Jvette73, 5:52 PM 8/8/2001]
Old Aug 8, 2001 | 08:15 PM
Joe Lucia's Avatar
Joe Lucia
"LT1man"-----
Most Corvette engines equipped with the air injection reactor system (AIR) were also originally equipped with 195 degree thermostats. All LT-1s were equipped with AIR and all were originally equipped with 195 degree thermostats.
Now, that just says that's what they were ORIGINALLY equipped with. If you wish the engine to operate at a lower temperature (and assuming that your cooling system is capable of maintaining a lower temperature) you can switch to a 160, 170, or 180.
To Thermostat Temp.
