69 350/350 Carb Issue
Old Feb 8, 2006 | 12:54 PM
SILENT BOB's Avatar
SILENT BOB
From: Tank sticker? I ain't got no tank sticker! I don't need no tank sticker! I don't have to show any stinking tank sticker!
Default 69 350/350 Carb Issue
Here's a carburetor question for the group: 69 Corvette, 350/350. Q-Jet recently rebuilt, appropriate places sealed with Dev-Con, new gaskets, needle/seat assembly, etc, brass float height set carefully per specs (float not leaking and sunk). This car does NOT have what I believe was original equipment: a fuel return line back to the tank from the fuel filter. It has just one line from the fuel pump to a filter, then into the carb. The problem is fuel bubbling up through the air horn and accelerator pump, and leaking all over the manifold. I have twice checked float height and needle/seat assembly for function and tightness, the seat gasket is in place, and there is no leakage past the needle/seat when held down manually. Yet the float chamber is overfilling. Any ideas?
Old Feb 8, 2006 | 03:35 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
What kind of fuel pump do you have? is it new and related to your problem? im thinking fuel pressure may be too high, buty Lars is the reputed forum Guru on Carbs, shoot him a message
tim
Old Feb 8, 2006 | 08:12 PM
StickShiftCorvette's Avatar
StickShiftCorvette
If you don't have the original fuel line you should add a fuel pressure regulator. A lot of Chevys did not have regulators or fuel returns - I'd assume their pumps were limited to about 7 psi.
Old Feb 8, 2006 | 08:27 PM
SILENT BOB's Avatar
SILENT BOB
Tim
It has a new stock fuel pump from major Corvette parts vendor so presume it is in the 7 psi range.
Old Feb 8, 2006 | 08:42 PM
69FI's Avatar
69FI
Do you have a vented gas cap?
Old Feb 8, 2006 | 10:28 PM
73 LS-4's Avatar
73 LS-4
I'm thinking along the same lines as everyone else, either your running too much fuel pressure overcoming the needle and seat assembly or the float for one reason or another isn't able to hold enough pressure on the seat to keep it from overfilling.
Pat Kunz
Old Feb 8, 2006 | 11:18 PM
BigBlockk's Avatar
BigBlockk
Does it do this all the time or just when the engine is hot? Could be the carburetor is getting too hot.
BigBlockk
Later.....
Old Feb 9, 2006 | 10:52 AM
SILENT BOB's Avatar
SILENT BOB
To answer questions - yes there is a vented cap and things were fine until the carb was rebuilt. Hot or cold it leaks fuel.
Old Feb 9, 2006 | 10:58 AM
sweethence's Avatar
sweethence
Default this may sound silly
In the q-jet there is also a small filter that sits in the carburator housing where the fuel line inlet is. (think there is a small spring). On my 68 i have the external in line with the fuel return, but i also kept the one in the carb in place( two is better that one ). Is it possbile by not having it its causing your problem?
Just a thought
tim
Old Feb 9, 2006 | 11:19 AM
69FI's Avatar
69FI
Did you put the wire clip of the needle into any of the holes in the float? I believe the clip is not supposed to do this, it just hangs on the bar of the float without going into any hole.
To 69 350/350 Carb Issue
