Hesitation on light acceleration
Old Feb 9, 2006 | 09:10 AM
Fubba's Avatar
Fubba
Default Hesitation on light acceleration
When going from a dead stop, I'm having a slight stumble problem. It's only during light to normal acceleration though. When I kick it, it's okay. I know I have two threads going right now, but these are two problems I'd like to take care of before the weekend. When the new heads were put on, the motor guy readjusted my Edelbrock 600 CFM carb. It idles great and actually runs wonderfully except for the acceleration thing. He said he set my timing at 28* because he said he's old school and doesn't want to worry about detonation and valves pinging. Do I need to advance it? Also, it idles at 600 RPM in gear and 800 RPM in park yet when I cut it off last night, it backfired through the carb or "dieseled" as some call it. Could this be associated with this problem? Another thing, the stock torque converter is about shot. It clunks hard in gear, and I'm sure it doesn't like my cam either. Could this be part of the problem as well? I'm open to ideas.
Old Feb 9, 2006 | 10:46 AM
Hvymtlc5's Avatar
Hvymtlc5
Make sure you have a little preloading on the accelerator pump, but not enough so that it bottoms out completly when you go to WOT.
Old Feb 9, 2006 | 02:42 PM
Fubba's Avatar
Fubba
The carburetor's an Edelbrock. I don't think they have an accelerator pump on them? I could be wrong though.
Old Feb 9, 2006 | 05:55 PM
BigBlockk's Avatar
BigBlockk
They do have accelerator pumps. You're not going to be able to fix this problem if you don't know what the parts of the carburetor are called. Didn't you get some kind of book or diagram with this carburetor?
Also unless the engine is put together with some kind of VERY strange combination it should be able to tolerate more than 28 degrees of lead. Your mechanic is an idiot because valves don't ping. Your initial advance should be somewhere around 16 give or take a few. Total advance should be about 36 degrees all in by 3000 RPM.
BigBlockk
Later.....
To Hesitation on light acceleration
