spark plugs
Old Feb 9, 2006 | 02:22 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default spark plugs
What is everybodies perfered brand of spark plug?
Old Feb 9, 2006 | 02:24 PM
454_71Stingray's Avatar
454_71Stingray
I have regular old AC delcos in mine but they are two steps hotter than origional. No complaints so far.
Old Feb 9, 2006 | 03:47 PM
Crash80's Avatar
Crash80
AC Delco Rapid Fire #2
Old Feb 9, 2006 | 05:42 PM
Guru_4_hire
Cruise-In V Veteran
OK the best I can tell I am going to need
Champion c61cx
NGK 4554
autolite AR3934 or 3923
they are written in the FAQ thread of another forum as "1 heat range cooler"
what does all this mean? I need a good plug for my boosted motor. I figure if I am gonna **** away good money to have plugs delivered to me I might as well get good ones.
Any input is acceptable
Old Feb 9, 2006 | 06:00 PM
1BAD80's Avatar
1BAD80
Best luck with NGK Golds, then Bosch Plus 4's #4418 and Autolite double plats #APP3924. These are 3/4" reach.
Old Feb 9, 2006 | 07:04 PM
guppie's Avatar
guppie
St. Jude Donor '08
AC Delco till I put headers on then I went to the short Accel's
Old Feb 9, 2006 | 07:25 PM
pef427's Avatar
pef427
What are the 427 guys running?
Old Feb 9, 2006 | 09:46 PM
pef427's Avatar
pef427
ttt
Old Feb 9, 2006 | 10:40 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I think I have Bosch platinums in the 77 now. I used to run NGKs in my Talon, they're good plugs, too.
Old Feb 9, 2006 | 10:49 PM
ltlevil's Avatar
ltlevil
I put the shorty accels in to break in the motor and do the tuning with, figured they would be a little easier to get in and out doing plug checks. After I ran them a while they seem to work well and my plug wires have a little extra clearance from the headers so I'll keep them til they let me down.
ltlevil
Old Feb 9, 2006 | 11:13 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
NON headers: AC Delco
With Headers: Accel Shorties
Old Feb 10, 2006 | 04:51 PM
Guru_4_hire
Cruise-In V Veteran
well I am picking up a set of 10 Autolite AR3934 racing plugs from the autoparts store tommorow. Sure beats the hell out of paying 10 dollars for shipping on plugs from summit
Old Feb 11, 2006 | 11:52 PM
bigblokvette's Avatar
bigblokvette
well, the 502 guys running nitrous are running autolite, or NGK.
Old Feb 12, 2006 | 12:04 AM
Ironcross's Avatar
Ironcross
R45XLS or R44XLS in the AC brand.. 43`s are a little too cold for the street.
Old Feb 12, 2006 | 03:13 AM
Kalway's Avatar
Kalway
What's the part # for the Accel Shorties?
Nevermind, I think I found it:
0276S
Old Feb 12, 2006 | 03:26 AM
mrvette's Avatar
mrvette
AS I recall, those are the numbers in AC D that are in fact maybe only 1/16 inch or so longer than then Accell shorties....so I went with them...
not worth the stupid price differance, I hose clamped a small piece of galvanized metal bent to header in position as a heat shield for the plugs cyl 5&6 only....
GENE
Old Feb 12, 2006 | 08:27 AM
pef427's Avatar
pef427
I was running these but decided to try the Champion 405's instead. I don't have an opinion about the car running better/worse...no noticeable change. BUT, the Champions came with rings installed and the gaps were all very consistent. The A/C's rings were off and the gaps from the factory were all over the place...
To spark plugs
Old Feb 12, 2006 | 12:21 PM
LS-Five's Avatar
LS-Five
East bound and down...
My favorites have been the Champion Gold Plus plugs. They have a fine wire electrode and a gold-palladium tip. But, sadly you can't hardly find them anywhere anymore...
Old Feb 12, 2006 | 12:24 PM
norvalwilhelm's Avatar
norvalwilhelm
I like Accel. It's the only plug I will use in the vet.
Old Feb 12, 2006 | 01:01 PM
Ed Blue 03's Avatar
Ed Blue 03
I've always liked Autolite in SB Chevys.
