What flywheel weight?
Old Feb 9, 2006 | 02:38 PM
gkull's Avatar
gkull
Default What flywheel weight?
All you guys with aftermarket manual trannies what kind of flywheel did you buy and how do you think that it reacts during your driving.
Old Feb 9, 2006 | 02:42 PM
big_G's Avatar
big_G
Richmond 5-Speed, stock heavy (about 40lbs.) flywheel. Shifts fine, but if I pull it, I'm gonna go with an L-88 piece.
Old Feb 9, 2006 | 03:33 PM
jackson's Avatar
jackson
Zoom makes 'em ... under 16 lbs ... wholesale about $90. We run 'em in stock circle track cars ... we don't shift much.
Old Feb 9, 2006 | 03:45 PM
gkull's Avatar
gkull
The reason I ask is because I bought the 22 pound billet steel 168 tooth. I want something that could change RPM quickly. The larger 40 pound like what you have. I just didn't know if it was for ease of driving and help in drag racing. I found an even lighter RR 18 pound, but durability is also on my mind.
I've got the 42 pound 4 inch stroker crank and 6.375 inch diameter light weight damper. Under driven March aluminum damper pulley. No Mechanical fan.
I'm an old motorcycle road racer and trail braking is how you square off corners. I was able to do that with some success in the vette by down shifting while braking and the rearend would come around entering a turn
Old Feb 9, 2006 | 03:50 PM
gkull's Avatar
gkull
What is the rated clutch hp? I was told that certian race bodies would not allow alluminum fly wheels. I also bought the blow proof bell housing and 850 hp, 11 inch clutch
Old Feb 9, 2006 | 03:54 PM
redvetracr's Avatar
redvetracr
Geo,
If you could just once drive something on the race track with a Quartermaster triple disc (NO I am NOT offering) you would NEVER EVER think of using anything else.....I have the 5.5" w/reverse starter which I doubt is streetable but I have heard of guys using a 7.25" triple disc on the street.
...redvetracr
Old Feb 9, 2006 | 04:09 PM
632C2's Avatar
632C2
George, I went with the factory Chevrolet 16# flywheel on this ZZ383 deal of mine. I just finished with the install of the Keisler TKO-600 5 speed and it's all good.
Steve
Old Feb 9, 2006 | 04:13 PM
gkull's Avatar
gkull
Howard, I have driven a triple disk in a Chevy power race car with a sequential tranny.
It didn't take me long to master it. I just had to remember to slip it and not be afraid. I've ridden so many multi disk race bikes that the transition wasn't too bad. Just a little noise and a little chatter.
I just bought what I could for now to get it running and I'll think of that kind of an upgrade later.
Old Feb 9, 2006 | 04:36 PM
jackson's Avatar
jackson
It's IRON ... hollowback ... I do not recall seeing an SFI or other rating. We're circle trackin' ... hard on-off throttle to around 7K ... I've never seen L88 iron 16 lb flywheel come apart on circle track ... clutch is a different matter. Zoom also has a matching "richard petty driving school" disk, pp, tob, pb ... pp & disk w/damper springs about 18.5 lbs ... w/tob & pb wholesales about $120 ... pp & disk with NO damper springs about 17 lbs ... w/tob & pb wholesales about $150.
Old Feb 9, 2006 | 07:59 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I run a 30# billet steel flywheel with an 11" clutch. I redline at 7000 RPM. If I were doing it again I would use the L-88 16# nodular flywheel with a 10.5" clutch.
Old Feb 9, 2006 | 09:47 PM
Solid LT1's Avatar
Solid LT1
L88 14lb flywheel here with over 14K miles and 2 centerforce clutches in the LT-1. Flywheel is excellent with good friction characteristics. I would never run one without a scattershield, I like my feet/toes too much.
Old Feb 9, 2006 | 09:51 PM
73C34me's Avatar
73C34me
25 lb. hayes with 11" clutch. I have to replace the disk. may go to a lighter flywheel next time. shift at 7100 with scatter shield
Old Feb 10, 2006 | 03:32 PM
Carl Johansson's Avatar
Carl Johansson
I'm not that good - I burned up a clutch and had some hairy excursions doing that. Id let out the clutch - the engine would be low RPM and the wheels still going fast -the rear end got squirrley and I was afraid I was hurting the motor. - thats when I understood that I needed to heal and toe - for me I get alot better control of the car going through the corners if I don't have a squirley rear end going into it. I do however often kick the rear end out with the throttle just before I come onto the straights - then steer to the rear end - fun as hell!
carl I ain't that good" Johansson
To What flywheel weight?
