shock mount removal,stuck.
Old Feb 10, 2006 | 06:39 PM
Matt 1980 L-82's Avatar
Matt 1980 L-82
Default shock mount removal,stuck.
Hey guys, I'm in the middle of trying to take apart the rear suspension to install a street and slalom kit, and I cant get the shock mount off. My shock mount removal tool doesnt fit and I cant bang it out even with a 10 pound sledge.
I can rotate it back and forth a little so its not siezed, but it wont move out at all.
any suggestions?
Old Feb 10, 2006 | 07:24 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Don't beat on it too hard, you could break the spindle housing (the two arms that the lower shock munt goes thru cannot take too much beating).
The strut rods have a inner sleeve that is often rusted to the shock mount.
Two options:
1) cut the strut rod off the shock mount and save the shock mount. This is a small surgery with a Dremel. New shock mounts are $50 each, the strut rods are a lot cheaper...
2) use penetrating oil and hope it loosens the sleeve.... Risk: you crack the arms when beating the $hit out of it.... that's going to be expensive...
Old Feb 10, 2006 | 08:03 PM
Matt 1980 L-82
we bought a little gear puller and tried to psh it out, but ended up stripping the threads on the cheap little Canadian Tire puller. is there any risk with using a bigger gear puller?
thanks for the help
Old Feb 10, 2006 | 08:16 PM
onaqwst's Avatar
onaqwst
just sawzall it off and buy new ones.....easier/less trouble....... try blasting it with rust eater ....maybe some heat.........drill..... i forgot how i got mine apart but i think i went on a rampage doing it and prolly threw soemthing across the garage too.........try soaking it with coke (the pop/soda)...i heard that stuff eats rust.....
b
Old Feb 10, 2006 | 08:32 PM
Matt 1980 L-82
thanks guys.
we were at it with a torch and tier rod end puller, the small gear puller, and finally hammers. we did get it to move a little with the puller before we stripped the threads.
I'm going to cut the strut off with the dremel tomorrow.
Old Feb 10, 2006 | 08:55 PM
DR.Jay's Avatar
DR.Jay
My time is to valuable to me to fight with a rusted sleve so I used my torch and cut the strut rods off. At $100 for a pair of adjustable rods it was alot cheaper time and money wise so I could move onto the rest of my project.
My $.02
DR. Jay
Old Feb 10, 2006 | 09:26 PM
72LS1Vette's Avatar
72LS1Vette
any suggestions?
The shock mounts have a flat spot on the shaft so they don't rotate. It's probably siezed onto the strut. When we disassembled the rear end on our Vette, one shock mount was damaged by pounding, and even VanSteel, who does this sort of thing all the time, coudn't get the other one off without damaging it. I had to saw the strut off just so I could ship the trailing arm down to VanSteel. Good luck, you are facing one of the tougher disassembly problems on the vehicle.
Rick B.
Old Feb 11, 2006 | 02:53 AM
Les's Avatar
Les
I'm in the process of doing this myself. On both sides I adjusted the jacking height until the shock mount was not bound up & would rotate slightly- as much as the flat part of the shaft would allow. On the driver's side I was able to wiggle & push by hand until it came out. On the passenger side I was only able to move it just enough to fit a big screwdriver blade between the shock mount & the spindle. A light pry with the screwdriver did the rest. If you can get a gap you may be able to do the same or use light taps on a pickle fork until it frees up.
Maybe I was just lucky but once I released the pressure by jack height it was pretty easy. I jacked the car up, dropped the car with 4X4s under the tires to gain working room, & then jacked the car from the middle to the right height to release pressure. I hope this makes sense- I'm pretty fried tonight.
Old Feb 11, 2006 | 09:42 AM
DaveL82's Avatar
DaveL82
Had one of the mounts on my 80 seize many years ago just like yours and as every has said the shock stud/mount is seized in the strut rod inner sleeve.
The best way to remove is to cut through the shock mount stud between the bushing and the spindle arms. I did it with a hack saw many years ago when I was poor.
PS - when replacing always apply grease to the stud and sleeve to stop it from occuring again.
Dave
Old Feb 11, 2006 | 10:06 AM
gator79's Avatar
gator79
Default don't hate me
after 35 years mine came right out, loosen the nut hit it twice with a hammer and came right out, of course I live in salt free Louisiana. I have read horror stories of trailing arm bolts and shock mounts siezed with rust.
Old Feb 11, 2006 | 11:02 AM
yellow71's Avatar
yellow71
Does this help?
Good luck
Old Feb 11, 2006 | 03:16 PM
Matt 1980 L-82
Originally Posted by yellow71
Does this help?
Good luck
yeah thats what I ended up doing. I cut the strut off the shock mount with a dremel and then I did that exact same thing with the tie rod end seperator to get the shock mount out. Biggest pain in the a$$ I have had with the car so far.
thanks for the help everyone, all of your suggestions were really useful in solving the problem.
To shock mount removal,stuck.
