Head gasket??
Old Feb 10, 2006 | 11:20 PM
Sayfoo's Avatar
Sayfoo
Default Head gasket??
69 BB 390hp, basically stock, with '71 low compression oval port heads.
Question--If I replaced the FelPro fiber type head gasket (part # unkown) with a stamped steel head gasket, would the compression ratio increase enough to matter? Any problems associated with the steel gaskets??
Old Feb 11, 2006 | 11:05 PM
jackson's Avatar
jackson
On an 8:1 motor, it will raise CR approx 0.2 - 0.3 ... if you're at 8:1 now ... it'll go up to about 8.2 - 8.3:1.
On a 9:1 motor, it will raise CR approx 0.3 - 0.4 ... if you're at 9:1 now ... it'll go up to about 9.3 - 9.4:1.
On a 10:1 motor, it will raise CR approx 0.4 - 0.5 ... if you're at 10:1 now ... it'll go up to about 10.4 - 10.5:1.
If both head & block surfaces are very true ... the thin steel shim gaskets will be fine ... otherwise, thin steel gaskets don't seal as well as composition gaskets.
Old Feb 14, 2006 | 11:14 PM
Sayfoo's Avatar
Sayfoo
Well, the best I've come up with is 9 to 9.5 cr, so now the question is, would I gain anything with a .3 to .5 increase? Alot of work involved. If I ever need to replace the head gaskets, I think I'll give it a go with the thinner ones. Thanks for the info.
Old Feb 14, 2006 | 11:31 PM
Cory1970's Avatar
Cory1970
true. I have a friend who is running steel shim gaskets and they leaked. His block was freshly decked and his heads were new out of the box. He took the motor back to the machine shop, and as it turns out the new heads needed to be resurfaced right out of the box. There was nothing wrong with the heads, but since the tolerences are so exact with steel gaskets they leaked.
So, if you plan on having your block out of the car and decked, and your heads resurfaced go for it. If not, stick with the felpro's
Old Feb 14, 2006 | 11:34 PM
GasketDude's Avatar
GasketDude
Stamped steel for BB? Who's?
What were you going to use? Fel-pro #1071-1 MLS gasket is .053" compressed, don't have catalog in front of me, but I'm not sure of a thinner one. Though some new stuff is coming out. Reference = Standard FP perf gasket thickness is .039".
Later.
To Head gasket??
