Muncie problem
Old Feb 11, 2006 | 03:25 PM
Motorcity81's Avatar
Motorcity81
Default Muncie problem
Thinking of buying a Muncie M20 from a local who said "sometimes it is hard to get it to downshift to 3rd gear... have to put it in 2nd then back to 3rd". I assume it is the syncros, but could it jsut be his linkage? Thanks.
Old Feb 11, 2006 | 03:47 PM
houstonvett's Avatar
houstonvett
St. Jude Donor '09, '24
If the car shifts from 2nd to 3rd and then 3rd to 4rth allright then you know the linkage isn't a problem. With the car going down the road in fourth gear depress the clutch and rev the motor a little and see if you can downshift into 3rd easier. If you can you will need new syncros, houstonvett
Old Feb 11, 2006 | 04:53 PM
Motorcity81
I should have been clearer, trans is now out of the car, so I can't try it out. Thanks for the input. Regards.
To Muncie problem
