Identify valves
Old Feb 11, 2006 | 10:12 PM
redcar1979's Avatar
redcar1979
Default Identify valves
I was replacing my water outlet (thermostat housing) on my 1979 L-48 engine. There are 2 valves screwed into the top of the water outlet which have vacuum hoses attached. While removing one of the hoses, I broke one of the plastic connectors. I do not know what this part is called so I do not know what to order. This part is on the driver side of the water outlet. It is the smaller diameter of the 2 valves. I followed the vacuum hoses back. They "T" into another hose. This hose goes to the spark advance and the other to the carburator. The top of the valve I need is a pale blue color. The other valve I do not need is yellow. Thanks for taking the time to read all of this and appreciate any help.
Old Feb 12, 2006 | 07:40 AM
Tom454's Avatar
Tom454
Those are "Ported Vacuum Switches"
Advanceautoparts.com lists purple, yellow, blue etc.
They ask for your VIN code so have it ready.
Old Feb 13, 2006 | 10:19 PM
redcar1979's Avatar
redcar1979
Thanks a million.
To Identify valves
