Transmission on or off?
Old Feb 13, 2006 | 06:38 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default Transmission on or off?
When I do replace my BB in my 73, do I attach the Keisler now or after the install. I have mixed opinions, what think you?
Old Feb 13, 2006 | 07:53 PM
icanfixitforyou's Avatar
icanfixitforyou
I have not done this myself, but was considering the install and read up on it. Most of the magazine articles state that they chose to install the trans and the motor as a unit. Something about non-removable cross members on some of our C-3's making it difficult. My .02 Good luck!
Old Feb 13, 2006 | 08:03 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
When I put my motor in I had the tranny installed. BUT, it was only the muncie tranny. I installed the Kiesler from below when it came time for that. I believe if I had the motor out and was going back, I would at least give it a shot with the Keisler mounted on the motor. Sure would make it a lot easier to do. You may want to invest in a tilter to get the motor at a better angle going in.
Old Feb 13, 2006 | 08:08 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
With out a doubt, if you are committed to not making the crossmember removeable, install the engine and Tremec as a unit. It will be easier by far. Just to give you the most maneuvering room, with the radiator removed, take the top two bolts on each side out of the core support and rotate the top of the core support forward. It is easy to do and worth the trouble. I have done this without even raising the car on jack stands, but you may want to do that because the Tremec is a little longer.
Bullshark
Old Feb 13, 2006 | 08:11 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Originally Posted by Bullshark
With out a doubt, if you are committed to not making the crossmember removeable, install the engine and Tremec as a unit. It will be easier by far. Just to give you the most maneuvering room, with the radiator removed, take the top two bolts out of the core support and rotate the top of the core support forward. It is easy to do and worth the trouble. I have done this without even raising the car on jack stands, but you may want to do that because the Tremec is a little longer.
Bullshark
This is what I have now[IMG][/IMG]
Old Feb 13, 2006 | 08:23 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Oh, you already have the core support removed Just drop the muncie and drive shaft and slide the the engine/tremec in as a unit. I still recommend you use a engine varable tilt motor lifting mechanisim.
If you are going to use the stock bell housing then you should be ok when the time comes to replace the clutch It will be challenging but still doable. If you are going to use a scatter shield, be prepaired to pull the engine again ( at least up and forward off the mounts)
Bullshark
To Transmission on or off?
