input for 383 build
Old Feb 14, 2006 | 06:19 PM
682XLR8's Avatar
682XLR8
Default input for 383 build
Helping out selecting pieces for engine build-ups seems to be a favorite topic here, so I thought I'd tap into this vast reserve of knowledge for some guidence. So far, I've got a roller block, with the rotating assembly and KB .030 flattops on the way. Now for the fun part....
Parts on the wish list so far are:
Comp Cams #08-450-8 286drgs, 230 @ .050, .560 lift
Dart pro 1 heads #11421112 72cc chamber, 200cc runner, 2.02/1.60 valves
Edelbrock RPM air-gap
Holley 750
I haven't bought any of these parts yet, so nows the time to make any adjustments to the list. We get 92 octane gas here, so any combo has to be compatible(reason for thinking 72cc's). Let's hear your advice, all input welcome!
BTW, engine will go into a 68 coupe, 200-R4 trans/2200 stall, 3:73 gears
Old Feb 15, 2006 | 03:05 PM
GDaina's Avatar
GDaina
Anybody have any ideas?
Old Feb 15, 2006 | 03:55 PM
big_G's Avatar
big_G
I wish I had used an engine build program like "Dyno-Sym" or "Engine Anaylizer Pro" before I built mine. Now I am in the process of making changes. Down-load the demo version of Engine Analyzer and try it. It will teach you about how engines work and perhaps save you some money...
http://www.performancetrends.com/EA30.htm
Old Feb 15, 2006 | 04:15 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
AFR 195cc Street Heads
9.5 to 1 Compression
1 3/4” Headers
AFR FloPower RPM #5028 and 0-4779 750 cfm Holley Carb
Comp Cams Hydraulic Roller Cam #12-433-8
MSD Distributor 36° Timing
93° Octane Pump Gas
Pay no attention to the right dyno chart, these parts are for the left dyno chart
Old Feb 15, 2006 | 04:18 PM
Rendler's Avatar
Rendler
I did the same setup that smokedtires displayed from the AFR site.
I LOVE it.
Hard to believe it runs that hard with no power adders using pump gas.
Old Feb 15, 2006 | 05:58 PM
682XLR8's Avatar
682XLR8
what piston type/head cc's for this set-up?
Old Feb 15, 2006 | 06:47 PM
Tonys96's Avatar
Tonys96
My engine is in the shop right now, getting similiar parts, the engine dyno is scheduled for next Thursday a.m.
Stock L-82 block, stroked to 383, Dart Pro 1 heads 180cc intake port 11121112, 64cc heads, Comp 12-432-8 or XR282HR-10 cam (retro roller), Comp Pro Magnum roller rockers, Dart Kool Kan intake (similiar to Edelbrock Air Gap, no longer available), a few other goodies.
I'll post the dyno results as soon as I get them.
Old Feb 15, 2006 | 11:27 PM
LFZ's Avatar
LFZ
I have a very similar build as yours...i'm running a 236/242 roller cam..very streetable..very nice cam...probably yield you more power than that single pattern cam.
Old Feb 16, 2006 | 08:43 AM
Rendler's Avatar
Rendler
I went with the AFR 195 heads. They are the 74 cc strait plug style. For pistons I used the JE - SRP forged flat tops with the two valve relieve.
I decked the block taking .020 off leaving the pistons .005 down in the hole.
Old Feb 16, 2006 | 10:40 AM
682XLR8's Avatar
682XLR8
Looks like the AFR's and dual pattern cams suggested would be a better choice than what I had in mind. With the 68cc chamber AFR head, what kind of compression will I get using a flattop piston(KB100030-8, 7cc in the valve reliefs)? CR is my main concern now, as I don't care to be the first on my block to have a diesel Corvette! Thanks for all the help guys, I'm sure glad I found this forum!
Old Feb 16, 2006 | 08:41 PM
79VetteMike's Avatar
79VetteMike
I have a very similar cam for my 396SBC build. I have some 200cc Aluminum Pro Topline heads that I'm doing alot of work on. Do you have any dyno numbers? How does it sound?
Old Feb 17, 2006 | 08:44 AM
Rendler's Avatar
Rendler
"With the 68cc chamber AFR head, what kind of compression will I get using a flattop piston(KB100030-8, 7cc in the valve reliefs)?"
I'm comming up with 10.45 using:
.038 gasket
-7 cc pistons
68 cc heads
0 deck height clearance
If you go with standard deck height of .025" it will be 9.89
.038 gasket
-7 cc pistons
68 cc heads
.025 deck height clearance
I used Engine analyzer to get these mesurements.
Good luck.
Old Feb 18, 2006 | 01:36 PM
LFZ's Avatar
LFZ
sorry, just now responding..been busy with school. I don't have dyno numbers on my engine, but my engine is built by a respected builder (Golen Engines) and he uses this cam on many 10.2:1CR 383s with AFR 195s, and he gets 500hp/480-500tq all day long. Sounds really mean..and idles really nice, not much lope. I have a clip. 383 vid
To input for 383 build
