Junk yard Fans
Old Aug 9, 2001 | 09:48 PM
john73bb's Avatar
john73bb
Default Junk yard Fans
I am using a dual fan from a Chrysler, and it just ain't cutting it. I think it would be just great if it didn't run so slow (designed to be quiet I think).
Can anyone recommend another fan that I can get from a junk yard that will cool my big block a bit better?
I already have a high performance radiator that keeps the car cool without a fan up to about 60 degrees or so.
Thanks,
John.
Old Aug 9, 2001 | 11:31 PM
flynhi's Avatar
flynhi
Default Re: Junk yard Fans (john73bb)
I tried a dual fan from a 96 but it didn't fit well - too deep front to back and hit the left upper control arm.
Old Aug 10, 2001 | 09:16 PM
john73bb's Avatar
john73bb
No one else has put a junk yard electric fan in their Vette? :confused:
[Modified by john73bb, 7:16 PM 8/10/2001]
[Modified by john73bb, 8:02 PM 8/10/2001]
Old Aug 10, 2001 | 11:23 PM
Rocket Ron's Avatar
Rocket Ron
I use a mid 80's F body fan with an adjustable fan thermostat. You will have to make a mounting for it but it does do the job.
Old Aug 11, 2001 | 12:44 AM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Well, I did install a fan from a Grand Am in my car, but that was only to supplement the engine driven fan. :crazy:
Dave
Old Aug 11, 2001 | 09:39 AM
mrvette's Avatar
mrvette
Default Re: Junk yard Fans (ddecart)
I used an '87 vette fan custom mounted in the stock '72 vette shroud, and edge trimmed in tight with pipe wrap.... :D
Old Aug 11, 2001 | 08:45 PM
john73bb's Avatar
john73bb
Default Re: Junk yard Fans (mrvette)
Well, I got a set from the junk yard today that is off a late 80's GM. it is a large fan with a resistor for two speeds and a small fan that goes next to it. If they both fit, I will hook the small one up to come on when the oil pressure is up, the low speed on the large one to come on at about 190 and the high speed to come on at about 205-210. I built a little opamp circuit that uses a GM temp gauge sensor and will activate the two relays for the two speeds. Hope it works.
Old Aug 11, 2001 | 09:18 PM
Stingy74's Avatar
Stingy74
I really wish I had a picture but I use a fan out of a 1990 Buick Century which I got from the wreckers. If fits nicely behind the stock 74 shroud. I even went to GM and got the factory harness plug for it. I wired it to run all the time. It's good for when you need to cool down faster after an autocross run.
To Junk yard Fans
