Intake plumbing
Old Feb 18, 2006 | 05:07 AM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Originally Posted by Z-man
OK - my idea...
Get a metal sphere about 5" in diameter. Drill a 3" hole and two 2.25" holes where ever you need to. Weld your pipes in...
Good idea. Should help flow.
And call it......drum roll....the "Powerball".
Old Feb 18, 2006 | 08:23 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Originally Posted by Corz
yes but that makes a plumbing NIGHTMARE
once you go through all the trouble of R&D'ing a turbo setup that mounts in front of the engines, and by the time you install it, you'll be saying "f**k!! i should have mounted them under the manifolds"
trust me, it's a HELL of a lot easier to do it this route. Even if you run an STi style intercooler, you'll be fine
No its not.
This has absolutely nothing to do with the intercooler. THe intercooler is simple.
Old Feb 18, 2006 | 09:44 AM
Monty's Avatar
Monty
Once you've gone through the process of fabricating a twin turbo system for our cars, you'll understand why placing the turbo's in front of the engine is a good option.
Old Feb 18, 2006 | 12:31 PM
Guru_4_hire
Cruise-In V Veteran
Monty to you remember how far it was from left to right in your setup there at its widest? approximately?
I am figuring my 34" wide shelf is about as wide as I am gonna get.
Old Feb 18, 2006 | 01:18 PM
Monty's Avatar
Monty
No, but the headers, turbos, wastegates, downpipes, etc had to be removed porior to removing or installing the engine, then reinstalled after the engine was in place. I'd say it was a good 2-3" wider than the hood opening. It could probably be made a little narrower by tucking the primary's closer to the heads and valvecovers but I wanted to make sure the sparkplugs and valvecovers could be removed without having to remove any of the turbo system.
Old Feb 18, 2006 | 03:36 PM
Guru_4_hire
Cruise-In V Veteran
Given that the radiator is 31" I am hoping that 34" is pretty close.
