Horsepower Question?
Old Feb 15, 2006 | 11:01 PM
78SA's Avatar
78SA
Default Horsepower Question?
I know GM changed the way they rated hp some time in the early 70s for insurance purposes, my question is what would be the hp rating on a 78 L-82 220 hp if it was calculated the early way? even a guess? thanks ray
Old Feb 15, 2006 | 11:08 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
no, that is not the early way, which went the way of the dodo bird in the very early 70's if not 1969
Old Feb 15, 2006 | 11:18 PM
Brad Maynard's Avatar
Brad Maynard
probably would be 60 or 70 higher, I think
Old Feb 15, 2006 | 11:22 PM
StickShiftCorvette's Avatar
StickShiftCorvette
Gross HP rating would be 275 to 280.
('L48 210 Net 270 Gross; LT-1 275 Net 330 Gross per GM in '71)
Old Feb 16, 2006 | 12:51 AM
Z-man's Avatar
Z-man
It wasn't for insurance purposes. The industry standardized their measurements and tried to reflect the actual engine output by measuring the power with accessories on the engine.
Old Feb 16, 2006 | 01:08 AM
Kalway's Avatar
Kalway
Gross horsepower was made by an engine with open exhaust and no accessories attached to it, while the engine was on a stand, not in the car.
Hence why they changed to net horsepower which measures the actual horsepower you'd get from it.
Old Feb 16, 2006 | 05:40 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Old Feb 16, 2006 | 08:18 AM
mandm1200's Avatar
mandm1200
That would be a fair guesstimate. The way they rated the horsepower and the addition of more pollution items lowered the hp rating.
Old Feb 16, 2006 | 01:53 PM
PRNDL's Avatar
PRNDL
I don't know if all GM models or all U.S. manufacturers changed at the same time, but for corvettes, you will note that up to and including the 1970 model year hp was gross, then in 1971 they did provide both gross and net (although I think still gross was used most frequently) then in 1972 they went to net hp ratings. That is why you see dramatically lower hp ratings from 1970 models to 1972 models with similar engines. There was a drop due to lower compression ratios and perhaps more smog equip (?) but the actual drop in hp is not nearly as huge as what you lost by reporting net hp instead of gross hp.
1970: base = 300hp, L-46 = 350 hp, LT-1 = 370 hp, LS-5 = 390 hp
1972 base = 200 hp,(no L-46) LT-1 = 255 hp, LS-5 = 270 hp
Old Feb 16, 2006 | 02:03 PM
Solid LT1's Avatar
Solid LT1
In 1971 GM made all engines able to run unleaded fuel. The compression ratios were dropped and different cylinder heads were put on the LT-1. The 370HP rating of the 1970 LT-1 was actually acheived with the 327-365HP 302-290HP "30-30" camshaft profile. The 1970 LT-1 cam is a little smaller than the 30-30 cam and I really don't think the 70 LT-1 is a true 370HP. The 1971-72 LT-1 motors are essentially the same so the HP dropped from 330HP to 255HP under the new SAE testing standards of 1972. You L-82 would "gross HP" at around 300HP using the old standards.
Old Feb 16, 2006 | 02:24 PM
Kalway's Avatar
Kalway
Geez now I wonder what my L-81 would gross after ridding all of the emissions crap, upping the compression slightly, and putting a better cam in.
Old Feb 16, 2006 | 05:01 PM
78SA's Avatar
78SA
Thanks guys, Very Interesting !!
To Horsepower Question?
