saving weight on 81 corvette
Old Feb 17, 2006 | 02:26 PM
mooneyd's Avatar
mooneyd
UKPAUL, you are right about chrome plating helping the wear on sprockets. Chrome plate is extremly hard and wears really well, it's the same as getting the teeth on the sprocket surface hardened.
Old Feb 17, 2006 | 02:31 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Isn't chome nickel? If not I was going to say nickle is softer then copper.
Density's:
Copper 8.97
Nickel 8.89
Old Feb 17, 2006 | 03:24 PM
Kalway's Avatar
Kalway
Well considering steel sprockets usually cost about 1/2 as much and sometimes 1/3 as much as their aluminum alloy counterparts, it's a pretty easy choice. The front sprockets are always already case hardened so least I don't have to worry about that wearing out, this time. However, whenever you change your sprocket, you need to change your chain and vice versa so I think from now on instead of spending $100 on that WX ring chain, I'm just going to go with the $25 solid one and get the aluminum sprockets and still spend less than steel + wx ring chain.
Back on topic, bumper reinforcements can be replaced with aluminum reinforcements to save a ton of weight.
Old Feb 17, 2006 | 03:25 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Density's:
Copper 8.97
Nickel 8.89
Um, well no.
Nickel is Nickel.
Chrome on the other hand is Chrome...
element 24 on the ol perodic chart
Old Feb 17, 2006 | 04:40 PM
bickel's Avatar
bickel
take your car to a scale first easy to loose weight look with vb&p for front leaf spring and new a arms and it will improve suspenion as well that gw was taken in 81 with a full tank of gas and alll kinds of stuff on and in the car do your exhuast and a few emisions stuff and your can get to 3000 easy! also look at taken weight for either front or back try to get distribution as close to 50/50 as you can for a hell of a ride if you are going for 1/4 mile lotta ways
Old Feb 17, 2006 | 06:50 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
redvetracr has his race car down to 2600 pounds but he won't tell us what the hell he did. Its a secret dammit.
Old Feb 17, 2006 | 07:22 PM
rcread's Avatar
rcread
I was going to say "Subway", but they don't have a drive-through.
Old Feb 17, 2006 | 07:38 PM
Kalway's Avatar
Kalway
There's one here that does, actually.
Old Feb 17, 2006 | 09:01 PM
MsVetteMan's Avatar
MsVetteMan
Radiator!!!!!!!!!! Did anyone say that?? If so, I missed it. What a difference in picking up the alum. w/ one hand vrs. the two handed beast!!
Old Feb 17, 2006 | 09:35 PM
rcread's Avatar
rcread
Just one more reason I need to move to San Diego.
Old Feb 17, 2006 | 09:52 PM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
Does your's have the steel mono(gymkhana) leaf spring? if so those way 50+lbs ..If so get a fiber mono leaf that only ways 8 + or - lbs and also make's a C3 handle better and the ride comfert is a night and day difference..
