Master Cylinder Question
Old Feb 16, 2006 | 01:01 PM
kodaclr's Avatar
kodaclr
Default Master Cylinder Question
I just bought a MC from VBP, My question is, are the threaded hole sizes suppose to be different sizes for the brake lines.
I have a 1969 with no booster
Old Feb 16, 2006 | 01:08 PM
Tom454's Avatar
Tom454
My 70 with P/B has two different sizes.
Old Feb 16, 2006 | 01:09 PM
Muddywaters's Avatar
Muddywaters
Just replaced the MC and Booster... mine are different sizes... which corelate to my porportioning valve i.e. front and back...
Old Feb 16, 2006 | 01:22 PM
kodaclr's Avatar
kodaclr
Ok thanks, Just wanted to check to make sure
Old Feb 16, 2006 | 10:37 PM
kodaclr's Avatar
kodaclr
Does any one know the size of the larger one? I'm trying to bench bleed and want to buy a short steel line to connect and bend back into the MC like people have suggested but I have not been able to find a brak line to fit the larger hole. I though it would be a standard size.
Old Feb 16, 2006 | 10:44 PM
TPL79's Avatar
TPL79
I went through this myself a couple of months ago.
I found an inexpensive kit, which came complete with threaded plastic adapters in various sizes and rubber tubing. The whole thing was about $8.00 and worked well.
I'm sure you can find the same kit online in case you don't want to hassel with bending short lenghts of steel lines.
Good luck.
Old Feb 17, 2006 | 07:47 AM
Tom454's Avatar
Tom454
!970=
Front- 1/2-20, 3/16" OD tubing
Rear- 9/16-18, 1/4" OD tubing
Old Feb 17, 2006 | 12:40 PM
kodaclr's Avatar
kodaclr
To Master Cylinder Question
