A/C repair info
Old Feb 16, 2006 | 03:50 PM
Wrecked82's Avatar
Wrecked82
Default A/C repair info
I know in advance that this is going to be controversial, but here goes.
For several years now, have not been able to keep a freon charge for more than a month - doesn't leak out overnight, just a slow death.
So, decided to use some of that stop leak stuff as a last resort to a more expensive repair.
First step was to put Pro-Dry in that converts any moisture to a synthetic oil compatible to all systems.
Second step - Stop Leak to seal any leaking o-rings and hoses.
Third step - Pro-Seal that seals metal leaks up to anything that will not leak overnight.
Fourth step - Add ES12A, yes, it is a hydrocarbon based refrigerant. But after researching flammability points, its flash point is higher than 134a. ES12A is also compatible with all oils and with R12, so no need to flush system.
Now, several months later, still charged up, and the system cools down very well. So cold yesterday (outside temps 80*) that I had to turn a/c down almost as low as it would go. Yes, 80* is not 100*, but it was so cold I had to turn all vents away from me.
For those who need a fix for less than $100 total, this is the way to go.
Old Feb 16, 2006 | 03:58 PM
Kalway's Avatar
Kalway
Too bad I yanked my a/c compressor out and put it in a box...
Old Feb 16, 2006 | 07:54 PM
jdmick's Avatar
jdmick
What's controversial about that? It sounds like a pretty good deal to me. Good job.
Old Feb 16, 2006 | 07:58 PM
Kalway's Avatar
Kalway
I think the fact that he used ES12A instead of R134a is.
Old Feb 16, 2006 | 09:33 PM
71rdster's Avatar
71rdster
Does ES12A require licensing or certification? Living in Texas, I have a Suburban as well as my Vette that could use some AC help.
Old Feb 16, 2006 | 10:32 PM
Wrecked82's Avatar
Wrecked82
Go here.
http://www.es-refrigerants.com/
No license needed.
To A/C repair info
