Need a 13x3 drop based air filter
Old Feb 17, 2006 | 03:15 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Need a 13x2 drop based air filter
any ideas?
Old Feb 17, 2006 | 03:16 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Why do you need a 13 inch diameter one?
Old Feb 17, 2006 | 03:40 PM
SanDiegoPaul
Been using a 14 inch edlebrock with a 3 inch K&N filter. I just added a 3/8 insulator under the carb and now there's two probs: First and foremost the filter hits the hood.
Secondly the bottom of the filter assembly now its the HEI plug wires and it hits hard enough where I know it will slice a hole thru two of these new expensive Taylor wires and arc out.
I sliced open a 3/8 inch PCV hose and put it along bottom of the chrome filter, by the wires. But then the filter won't go on the carb - that's how tight it is. I can get it on there if I dont protect the wires but I know it's too tight to drive it like that. (even IF the TOP didn't hit the hood)
Old Feb 17, 2006 | 03:53 PM
ltlevil's Avatar
ltlevil
Paul, they make on offset filter base just for this situation. Carb hole is offset ~1-1/2" from center to allow for clearance at the dist. area.
ltlevil
Old Feb 17, 2006 | 04:03 PM
SanDiegoPaul
ltlevil
THANK YOU!!!!!! You may just have saved the day!! <now to find one locally so I can drive it without waiting for shipping>
Old Feb 17, 2006 | 04:12 PM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
Any local speed shop that has dirt track racing or something similar should have one in stock...at least that's my experience.
trw
Old Feb 17, 2006 | 04:18 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
trw
This will work if he has a q-jet only. why not put some wire loom or something that will stop the wear.
Old Feb 17, 2006 | 04:29 PM
Tom454's Avatar
Tom454
I don't know if this is relevant or not, but I had to use a 13 x 2.5 element... had a hard time finding one... NAPA #FIL-2102. Just picked up 2 replacements today. Base is drop base.
FWIW
Old Feb 17, 2006 | 04:35 PM
SanDiegoPaul
See attached images ... wire loom won't fix interferance.
First is the old drop base, sitting on top of the ol' K&N filter element
Next is an overview of the engine
Next is my underhood insulation with a new hole in it from carb stud
last you will see the interference between the base and the distributor
Old Feb 17, 2006 | 07:13 PM
crazywelder's Avatar
crazywelder
If it were mine, I would make an offset air cleaner from the parts you already have. First check to see how much hood clearance you have at the front of your air cleaner with clay to determine if an offset will work. Cut the center of the base out around flat area by the carb opening. Shift the base forward until there is clearance for the distributor and mark the new location and clamp the pieces together. It's best to weld the pieces back together and metal finish them, but if you don't have access to a welder, you could screw and glue the pieces together with the screw heads underneath the base. There will be a gap where you shifted the 2 parts that you'll need fill with another piece of scrap sheet metal. To make the lid fit, you'll need to heat and bend the air cleaner stud to allow for the shift. If you don't weld all of this, you should seal the edges. You mentioned the stud hits the hood, you can try a Mr Gasket flat chrome lid, which will allow you to shorten the stud quite a bit. Before you close the hood check for clearance at the front and center with clay.
Old Feb 17, 2006 | 09:11 PM
pef427's Avatar
pef427
I use a bolt with a tapered flat head that has an allen head on top instead of a carb stud. This fits flat on top of the lid when tight. Email and I may can send pics. If this isn't too much of a "Bubba" fix you could clearance the back edge of your pan edge. It shouldn't require much material removal and would eliminate any sharp edges.
Old Feb 17, 2006 | 10:12 PM
ltlevil's Avatar
ltlevil
No-the base will fit Holley/Demon carbs, also has reliefs for the float adjustment screws.
ltlevil
Old Feb 17, 2006 | 10:19 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
ltlevil
Hmm ive never seen them that fit holley demon crbs and I have pretty much every circle track magazine and been to many NASCAR surplus shops.
How are they going to offset the air filer if the carb barely fits in the drop now?
This is mine. I have no top and I cut the bottom down at an angle. The hood seals the filter. Notice how the carb barely fits.
Old Feb 17, 2006 | 10:56 PM
ltlevil's Avatar
ltlevil
[QUOTE=Yellow73SB]Hmm ive never seen them that fit holley demon crbs and I have pretty much every circle track magazine and been to many NASCAR surplus shops.
QUOTE]
Don't really see how the carb fits, I know what you're thinking but they are around. They may not be offset the full 1-1/2" but they are made, Summit has a Moroso one that may work. Also why didn't you just buy one or at least do a little better fab job with yours? Pretty nice car to start bubbafying-course that's just my opinion.
ltlevil
Old Feb 17, 2006 | 11:00 PM
SanDiegoPaul
With that dist you would never have the clearance problem I have at the back.
Old Feb 17, 2006 | 11:37 PM
ltlevil's Avatar
ltlevil
My unilite is a lot smaller diameter than an HEI.
ltlevil
Old Feb 18, 2006 | 08:30 AM
SanDiegoPaul
To Need a 13x3 drop based air filter
Old Feb 18, 2006 | 10:00 AM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
[QUOTE=ltlevil]
QUOTE]
ltlevil
I can't figure out how to smooth it out with out using anything that could go into the engine.
Old Feb 18, 2006 | 11:04 AM
SanDiegoPaul
Yea! That would certainly make the 'air filter' counterproductive!
Old Feb 18, 2006 | 11:17 AM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Im going to get a carbon foiber one next time im at a NASCAR shop though.
