One headlight is not working correctly..goes up and down but does not lock well
Re: One headlight is not working correctly..goes up and down but does not lock well (Alwyn678)
there is an adj for that, look up at the light housing from underneath.i think it adj with a screwdriver
If it used to work OK and now it doesn't I would check for broken springs and loose bolts. Check for broken springs first. There should be four on each side. :smash:
