installing harmonic balancer question
...by the time you get the inner ring hot enought to expand enough to clear the crank snout you'd be sure to damage the rubber ring or the adhesive that bonds it to the outer ring.
Use the installation tool! As others said, Autozone rents many of these specialty tools and if they don't have a damper installation tool for rent, for chris' sakes they're only about $35 to buy outright.
I know there is a Fastenal located near you. They sell our products and have all kinds of bolts. If they don't have it in stock I'm sure they can get one.
www.fastenal.com
I think the Lakewood store is the closest one to you
It's amazing to me how many ways can be suggested to half azz a job when there's a $35 f-ing tool out there that can be bought at any corner auto parts store to do a job correctly. What's a new balancer cost? A cheap piece of Szhit Chinese balancer will cost $80 and good one $250+, damaging the thrust flange on a crank will cost you $200-$1200 depending on whether you end up replacing a cast crank or a forged/nitrided racing SB crank...not to mention the labor involved in replacing it.
...Then I read that the normal operating temperature of a balancer is 300 'F + ...Jeezus!! What science fiction novel did you read THAT factoid in?? Your coolant temp. should rarely reach 240'F and if your oil temp exceeds 270' it's starts breaking down into its elemental carbon again, so WTF makes you think your harmonic balancer runs at 300'F all day long???
Heat it, beat it, weld it!? What's the difference????
SIMPLY AMAZING!!!!
Hint to the author of this post: buy a $35 harmonic balancer installation tool and save yourself a lot of grief and having to read posts written by science fiction authors!
Sorry for my rant, and vagueness in expressing my opinion....er, statement of the obvious.
SIMPLY AMAZING!!!!
And you don't leave it in and set the timer, we're not baking here. Just leave it in for a few minutes. This is also what my buddy with a 67 Camaro did for his SBC.
Here's your science fiction.
SIMPLY AMAZING!!!!
180-250 what ever it takes to get it on there will help.-Mark.
I have actually seen clear rocker covers at a local show before. But they were coated with oil, and it didn't look that cool. Thanks though.
SIMPLY AMAZING!!!!
Using the installation tool is the only way to go!!
True, true. Sorry for being defensive.
