spec clutch
Old Feb 19, 2006 | 07:33 AM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Default spec clutch
Anybody running one of these? I am debating between the stage III and the stage III+ I want a pedal that is as light as possible.
Old Feb 19, 2006 | 07:38 AM
enkeivette's Avatar
enkeivette
I've got the SPEC Kevlar one on my 6 Speed good for 500hp. I think it's stage 2. I've heard bad things about the ceramic one. Sometimes they get stuck to the flywheel, and they always chew up the flywheel pretty quick. Mine is grabby and has a nice pedal feel. Barely stiffer than stock. But it does have clutch chatter, especially in reverse, common problem with these on LS1 tech.
Old Feb 19, 2006 | 07:42 AM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Thanks for the feedback!
Old Feb 19, 2006 | 08:43 AM
norvalwilhelm's Avatar
norvalwilhelm
Are you running mechanical linkage. The hyrdraulic system allows you to run a stiffer clutch and yet have a light pedal.
Old Feb 19, 2006 | 08:46 AM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Yes, factory equip.
Old Feb 19, 2006 | 04:17 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Come on now guys, I have to order in the morning. opinions?? Nitromad suggested either one, I am curious if anybody is running them.
Old Feb 19, 2006 | 09:34 PM
Daffy2's Avatar
Daffy2
Default spec clutch
Can't help you out (yet). Got a Spec 3+ in a current project (400 hp SB Fiero) but haven't run it yet. The Camaro boys like them and one of my Techs has a 3 in his LS1 z28. He says they're fine if you use 'em like you meant it. If you baby them, they'll chatter. We don't intend to baby it, expect it to work great. Good quality parts from what I saw when I put it on.
Daffy
Old Feb 19, 2006 | 10:03 PM
Corey_68's Avatar
Corey_68
I have 500miles on my Spec III, good for 650hp. Great clutch, no chatter and fairly easy pedal pressure.
HIGHLY recommend it, call PAUL @ Thunder Racing and he'll hook you up w/ a Forum Discount.
http://www.thunderracing.com/
Old Feb 19, 2006 | 10:07 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Thanks Corey, I will work on it in the AM. Curoius about the stage III+ too.
Old Feb 19, 2006 | 10:12 PM
Corey_68's Avatar
Corey_68
Not sure how much power you're making (I'd imagine I'm making around 550hp-/+(DD sates 610hp)) but keep in mind the higher the stage the less driver friendly. Paul has a Stage IV in his LS1 SS but it's making some serious power and he recommed a stage III if I planned on driving it on the street a lot.
Old Feb 20, 2006 | 01:35 AM
enkeivette's Avatar
enkeivette
Definitely, get the stage 3 or even 2 if you can get away with it. No reason to chew up your flywheel anymore than you need to.
To spec clutch
