Drop Base Air Cleaner
Old Feb 20, 2006 | 12:21 AM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default Drop Base Air Cleaner
Am preparing to install an RPM Airgap and either Holly or Demon Carb... Any suggestions for a good drop base aircleaner and what drop amount I should be looking at?
Old Feb 20, 2006 | 05:18 AM
enkeivette's Avatar
enkeivette
I've got the Performer RPM (same dimensions) and a Mighty Demon, Summit sells a 1 1/4" (about) drop base assembly for $40 that clears the stock 78 hood with this combo.
Old Feb 20, 2006 | 06:13 AM
DaveL82's Avatar
DaveL82
I run an Edelbrock cleaner when I have the Holley on.
Old Feb 20, 2006 | 09:35 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
I bought one at Auto Zone. Larry
Old Feb 20, 2006 | 06:33 PM
OldCorvetteKid's Avatar
OldCorvetteKid
The K&N X-Stream breathes through the top too...and lots of colors..the 14" with the 4 3/4 drop works great...however an Air Gap manifold WON'T fit under a stock hood.(no hood specified in your post,but thought inquiring minds would want to know)
Old Feb 20, 2006 | 08:11 PM
lebvette's Avatar
lebvette
If your working on the 80. It will fit. These year models have the bump in the hood which makes it possible. I have a similar motor in a 82 with a RPM air gap and a 770 Street Avenger and with a drop down filter. In fact, it will be a little easier for you. I had to cut the cold air duck from under my hood, I don't think you have any extra meat under yours. Like I said earlier, I bought my filter at Auto Zone bought a K&N filter at A/Z (3" high...you could go shorter) I also bought the extreme top(Summit)I wanted to make sure I got enough air. The drop down base, I bought locally, also cleared my choke and dist. I had to loose the pretty wing nut, tho. Good luck. Larry
Old Feb 20, 2006 | 08:44 PM
80TexasC3's Avatar
80TexasC3
Not my car...but the hood is the model that will be installed when it comes out of the paint shop in about 5 weeks.
Old Feb 21, 2006 | 06:41 AM
enkeivette's Avatar
enkeivette
This is the Summit drop base assembly and the Summit top. Over my Mighty Demon and my Performer RPM which I believe is dimensionally identical to the air gap version, all under the stock hood.
Old Feb 21, 2006 | 08:54 PM
80TexasC3's Avatar
80TexasC3
Thanks... can you tell me what the drop measurement is and the sumitt part number would be great if possible!
Thanks... Ed
Old Feb 21, 2006 | 09:44 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Thanks... Ed
Yep I need it too!
Old Feb 21, 2006 | 09:51 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Wrong
Old Feb 21, 2006 | 09:59 PM
Taijutsu's Avatar
Taijutsu
My 74 has air gap w/drop base and fits w/ 3/4" space. My dyno guy told me that w/drop base a filter lid helps. The air has to make a turn into the carb. The lid helps smooth the air.
Rick
Old Feb 21, 2006 | 11:01 PM
Augustus's Avatar
Augustus
Actually I wanted to know the same thing... Will an Eldebrock Air gap manifold and Holley 780 fit under my 73 Hood with a drop base air cleaner?
I have a 70-72 style dual snorkle and seems to be a lower rise than the 73 Air cleaner.. Would that work?
Old Feb 21, 2006 | 11:05 PM
enkeivette's Avatar
enkeivette
Top - SUM-239501 (You don't need the top obviously)
Assembly - SUM-239433
Copy Cats!
...They also sell the top with a black ring.
Old Feb 22, 2006 | 11:21 AM
80TexasC3's Avatar
80TexasC3
thanks
Old Feb 22, 2006 | 04:43 PM
68vertible's Avatar
68vertible
And it fits by the HEI too....sweet! I'm trying to get something to shoehorn my Vic Jr and Holley 750dp under my stock sb '68 hood and here's hoping this setup does the trick!
Old Feb 28, 2006 | 08:00 PM
80TexasC3's Avatar
80TexasC3
I ordered the drop base setup as noted above and all works well under the stock hood of my 80! Only diff overall is I am using an RPM Air Gap intake and a Speed Demon Carb.
Thanks for the help!
Old Feb 28, 2006 | 09:02 PM
81cali's Avatar
81cali
Hi torqvette,
i checked out summit and there were 3 variations of the drop. What should I get for my 81? Am using a torkerll with carter AFB 750
Old Feb 28, 2006 | 10:05 PM
enkeivette's Avatar
enkeivette
SUM-239433 has the biggest drop.
To Drop Base Air Cleaner
