What do you think about this crate engine from Chevy
Old Feb 20, 2006 | 11:07 AM
cal camara's Avatar
cal camara
Default What do you think about this crate engine from Chevy
It is brand new, 4 bolt, three year waranty. Afreind got it to hop up a bit, but it dynoed at just under 300 HP. It is under $1500.00. Old style valve cover bolts. Any ideas on how to get 30 more HP.
Copy link.
http://www.crateenginedepot.com/stor...53--P62C0.aspx
cal
Old Feb 20, 2006 | 11:10 AM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
New cam.
Old Feb 20, 2006 | 11:35 AM
Entropy's Avatar
Entropy
St. Jude Donor '08-'09
Good base, but you need to be careful about what cam you pick. The CR of 8.5 to 1 is going to limit you. The L82 cam (.450 lift, around 220 duration) seems to be a good cam for low compression motors. Not a bad deal for $1500. I'd drop 58cc heads on to it to bump up the compression, and run a higher lift cam. Then it'd scream.
trw
Old Feb 20, 2006 | 11:56 AM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
trw
Basically this.
http://www.crateenginedepot.com/stor...609-P4C53.aspx
Old Feb 20, 2006 | 12:00 PM
rcread's Avatar
rcread
trw
Good call on the heads and cam. 58 cc L98 heads should really help waken up throttle response and torque. These heads aren't very expensive (there is a complete pair on ebay for $600) and will save about 50 lbs in weight.
Old Feb 20, 2006 | 12:48 PM
Fevre's Avatar
Fevre
Do a google search on the 'Goodwrench quest' to see what Chevy Hi Performance got out of it, I bought one and stabbed a little bigger cam in it to start and went up from there.
Here is a good link:
http://rustpuppy.org/chp/
Old Feb 20, 2006 | 01:11 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Call me nuts but the thing that kills me about GM crates is the Mexican Made Hyper pistons.
Old Feb 20, 2006 | 01:19 PM
TedH's Avatar
TedH
8-Part Goodwrench Quest series from Chevy High Perf website:
the series: http://www.chevyhiperformance.com/te...61/index3.html
Part 1: http://www.chevyhiperformance.com/te...320/index.html
Part 2: http://www.chevyhiperformance.com/te...326/index.html
Part 3: http://www.chevyhiperformance.com/te...359/index.html
Part 4: http://www.chevyhiperformance.com/te...364/index.html
Part 5: http://www.chevyhiperformance.com/te...370/index.html
Part 6: http://www.chevyhiperformance.com/te...438/index.html
Part 7: http://www.chevyhiperformance.com/te...461/index.html
Finally, Part 8 (the summary): http://www.chevyhiperformance.com/te...467/index.html
Old Feb 20, 2006 | 03:43 PM
Wrecked82's Avatar
Wrecked82
Copy link.
cal
For about 200 more, get this:
http://www.goautocenter.com/350_1971-85.htm
Old Feb 20, 2006 | 03:46 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I would never install an engine without aluminuym heads due to the octane available.
Old Feb 20, 2006 | 06:35 PM
Demonic Possession's Avatar
Demonic Possession
Great read There should be a stick on here that has all sort of good links...
Old Feb 20, 2006 | 07:46 PM
Duke94's Avatar
Duke94
Installed one in my 78'. Added Al heads and cam, worked great.
Pace has them for $1295.
http://www.paceperformance.com/index...S&Category=142
Old Feb 21, 2006 | 11:00 PM
Fevre's Avatar
Fevre
I have beat the hell out of mine, 6500 rpm's a number of times when I had a roller cam in it, it has lived so far but I am going to keep it below 6k from now on so it will keep going for a few more years
BTW I don't think the piston's are hyp, just the plain cast alum, the hyp piston come in the zz4 and 383 eng's
To What do you think about this crate engine from Chevy
