Tubular Lower control arms?
Old Feb 20, 2006 | 08:30 PM
84rzv500r's Avatar
84rzv500r
Default Tubular Lower control arms?
I'll ask if I can get these uncoated. I can see some flanged lighting holes in that lower plate. Also need to weld on a stud or tab for sway bar... If I welded a stud on I could use a rod end for the lower mount... 30 lbs for the pair seems a bit heavy...
tubular lower control arms...
Old Feb 20, 2006 | 08:47 PM
84rzv500r's Avatar
84rzv500r
Available un-powdercoated but with an estimated 4-6 week lead time (between batches)
Your mileage may vary!
Old Feb 21, 2006 | 09:24 AM
SmithBros's Avatar
SmithBros
What are the control arms for? Impala?
Old Feb 21, 2006 | 12:37 PM
Kid Vette's Avatar
Kid Vette
What he said.
Old Feb 21, 2006 | 06:34 PM
ZD75blue's Avatar
ZD75blue
My concern with these... is they could be aimed at low rider impala's. IE, hydraulics...
When I pull mine off I'll have to weigh them....
Old Feb 21, 2006 | 07:50 PM
84rzv500r's Avatar
84rzv500r
58-64 Impala with Coil Springs... The Silver ones are for Hydraulics and air bags.
15 lbs a piece... I'll drop some weight from them... I can either hole and flange 'em or hit them with the CNC plasma cutter
I'll pull a Norval on the spring mount with the mill... a ton of metal can be pulled out without hurting the strength
I also have a set of poly coil spring mounts floating around somewhere in the garage I think I can turn them down on the lathe an have the spring set into them
I also need to weld a tab or stud (undecided) to mount the swabar link
Old Feb 21, 2006 | 08:38 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I beleive only the impala uppers fit our cars.
Old Feb 25, 2006 | 12:32 AM
84rzv500r's Avatar
84rzv500r
Ya think?
Use the force Luke...
To Tubular Lower control arms?
