wiper door problems
Old Feb 21, 2006 | 06:54 PM
694speed350's Avatar
694speed350
Default wiper door problems
When i start my 69 the wiper door opens. it will stay open. wiper switch is in off position. drive the car wiper door stays open. when i get ready to park the car in the garage the door will close. any body got any suggestions?
Old Feb 21, 2006 | 07:05 PM
birdsmith's Avatar
birdsmith
Under the right hand wiper arm there is a little plastic valve that is opened/closed when the wipers are either turned on or off. I was experiencing a similar problem with mine and replaced this valve and the problem went away.....you can get a vacuum system troubleshooting book from Dr. Rebuild or Mid America; the system ir actually quite simple. I think I bought the part from Dr. Rebuild, about $18 if I remember correctly....
Old Feb 21, 2006 | 07:40 PM
694speed350
Thanks birdsmith will check on it.
To wiper door problems
